Sealing Gas Tank Leaks?
So heres my pickle: Before I had my bike painted my gas tank didn't have a rear bracket to bolt the back down. So I had my painter weld 1 on. Its worked fine for years but now its started leaking out of a small spot on the end of 1 of the welds. The tank is aluminum and nobody wants to try and weld it cuz its so close from the underside to the painted surface! So my ? is has anyone tried those epoxy sealers that you pour in your tank that form a liner inside? Seems like about my only option left!?
we carry kreem here at Dennis Kirk that work's great. The part number for that is 31-52. let me know if i can help out.
__________________
Unmatched benefits of shopping with Dennis Kirk:
150,000 Parts Online - Same Day Shipping - Lowest Price Guarantee - Free Shipping on Orders Over $100
www.denniskirk.com
Enter our Sweepstakes! Join our FaceBook fan page for details on how you can get your hands on a customized Road Star for FREE. Click here.
www.denniskirk.com
Head to your local hardware store, they should have J-B Weld or another brand of epoxy that is made to patch holes in gas tanks. Several years ago I found some clear glue called something like "seals all". Wish i could remember the name of it or find it again. It worked great.
I wouldn't mess with the liner unless the inside of the tank is rusty or there is a leaky seam.
I used the seal all for awhile,but that fix only lasted a month or two.I contacted my painter and told him my problem.I didn't have the money for another tank and paintjob.I dropped the tank off at his shop to see what he could do.He used some sort of 2 part mixture to re line the inside.The new liner is smooth and hard as a rock after it cured.I'm not sure what it was called though.So far,so good no leaks.Here's his contact info.You can get in touch with him and maybe he could help more.
http://visualimpact2.com/Pictures.html
Forgot about J.B. Weld another fine product that I have used on Model A Ford engines to seal water jacket leaks....The one tank, I sealed in 1981 is still holding with Por15 but I am sure J/B will do the same job...I would inspect the inside of the tank first...Then decide.
