Notices
Just purchased a used Dyna, now leaking oil, found it to be overfilled , Best Fix?
Old 04-18-2010, 10:06 PM
fastjoe's Avatar
fastjoe
fastjoe is offline
Oh, one other thing you can check. I'm not totally sure if the new bikes have it, but my 95 has a little vent hose ontop of the transmission. If the transmission is overfilled it will puke oil out of it and run down between the trans and primary.
Old 04-18-2010, 10:12 PM
1skrewsloose's Avatar
1skrewsloose
1skrewsloose is offline
That's a good thought, may not even be coming from the primary, worth looking in to.
Old 04-18-2010, 10:53 PM
oct1949's Avatar
oct1949
oct1949 is offline
If Ur not sure on when it was serviced I'd just change filter and all three holes any way,
then start from there.....
Old 04-18-2010, 11:32 PM
joewg3's Avatar
joewg3
joewg3 is offline
Interesting. I recently had my tranny cover off and some fluid came out and ran all along the bottom of my bike. I just took it to the dealer because of an idle problem and they called me up and said that I had a primary leak. Sort of makes me wonder now because I've never had anything drip - not even parked in the same spot in my garage over winter!
Old 04-18-2010, 11:39 PM
harleydavis's Avatar
harleydavis
harleydavis is offline
Use the turkey baster to remove enough oil to get it below the fill line. Then ride the bike until it is warm and check the oil again. Continue removing oil until it is just below the fill line warm. Then clean the excess oil from under your bike and see if you have any leaks. It could be something as simple as your oil pan gasket, which I had to replace on my GF's Dyna for the same reason you explained.
Do the simple things first!!
Old 04-18-2010, 11:50 PM
RandyDowdy's Avatar
RandyDowdy
RandyDowdy is offline
If the oil is still clean, drain it all out and put it right back in, minus a little of course. Ride and check, ride and check, til you get it figured out.
tnichols
Oil Archive (no new posts)
17
05-31-2018 08:18 AM
DBLXX
2014-2023 Touring Models
31
06-06-2015 09:57 PM
adelii
05-20-2014 04:31 PM
texfatboy
04-03-2007 02:49 AM
BarryN
05-16-2006 02:05 PM
Quick Reply: Just purchased a used Dyna, now leaking oil, found it to be overfilled , Best Fix?
