Fuel Management Systems and HD Warranty
Old 04-18-2010 | 11:40 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
The Tmax will void your warranty because it replaces the factory ECM with an aftermarket unit. The dealer will have no problem refusing warranty work. Of course you can always spend $5-10,000 to hire an attorney and sue them and prove them wrong. So much for the Magnussun Moss warranty act. Otherwise, I would recommend you get the SEST or the TTS system and have the dealer dyno the bike if the warranty is a concern.
Old 04-19-2010 | 10:46 AM
fishcop's Avatar
fishcop
Default Thanks
Thanks for the good thoughts and advice. I think he is convinced that the PC V is the way to go. Cheaper and can be removed if "necessary".
EdwardK unfortunately the Magnuson-Moss Act will not protect you because replaced an entire item. Especially, an ECM which is the brains of the bike and controls many functions. This I got from an attorney friend.
Mchad
03-31-2015 03:14 PM
ajdrr
04-22-2010 09:38 AM
patsac
11-01-2007 01:54 PM
VicDawg
09-26-2007 09:55 PM
spokes54
11-30-2006 10:42 PM
Quick Reply: Fuel Management Systems and HD Warranty
