Is there a "Governor" set on Harley's?
If your motor has stock cams, springs, etc. your powerband is flattening out before the redline, so you need to upshift sooner. Don't just increase your redline if you don't have any other engine mods or you may be needing some major mods.
A stage one download on your bike will raise the limiter, as mentioned before. I've never understood the reasoning behind that.
Cadman, do you seriously think the redline on a Harley push rod engine is 8,000 rpm?
http://auto.howstuffworks.com/harley2.htm
LOL, sure you weren't reading about a V-rod? They will rev to 9,000.
Here's what a specific writer, Joe Minton, in a specific magazine, American Rider
Conclusion:
"The two most common reasons for engine failure of modified Harley engines are excessive rpm and detonation. A stock Harley Evo or Twin Cam engine, used moderately, can last 100,000 miles or more. Really. The same engine will be destroyed in a few miles if run at 1,000 rpm past its factory redline.
Detonation can destroy an engine so quickly that you won't have time to close the throttle before it hammers the pistons to scrap. I have done this. So keep the revs within the limits of the engine, which is about 6,000 rpm for a Big Twin and 7,200 for a Sportster.
If you detect any signs of detonation you must correct the problem immediately. Detonation, even a mild case, is going to destroy your engine and you must do whatever is required if you are to avoid the expense of a major rebuild. "
http://www.americanrider.com/output.cfm?id=1021915
8,000 RPM is two thousand past a Big Twin engine's max redline.
Conclusion:
