Nail hole in tire
Nail hole in tire
When i was on a quick ride before work the other day i ran over something. Got home and looked the bike over and didnt see anything wrong. 2 days later i went out to the garage and sure as sh@$ my rear tires flat. So i took the wheel off the bike and pumped it back up and found a very small hole where a nail or something went through the tire. I only have about 1000 miles on the tire. Can they put a patch on it from the inside or should i just buy a new tire? Thanks
I'd plug it with the plugs you push in from the outside of the tire, quick and easy. You could use one of the patch/plug type plugs but it would be a lot more work.
It could be tough getting a dealer or tie shop to plug it, most won't.
http://www.dunlopmotorcycle.com/info....asp?id=13#tip
