Opinion, Split Fire plugs
Old 04-09-2010, 07:42 AM
Wallaby's Avatar
Wallaby
Wallaby is offline
Splitfires = Marketing.......don't bother
Old 04-09-2010, 07:49 AM
Ratster's Avatar
Ratster
Ratster is offline
Originally Posted by King FLH
I remember reading about testing Smokey Yunik (great mechanical mind) did years ago when these things came out. His group found that they gave no performance edge at all, and actually promoted pre ignition due to the ground electrode had so much surface area, it would actually glow at the ends and pre ignite the incoming fuel/air charge under certain conditions.
Splitfires have been around for a long time now, so somebody's buying them.
Exactly. Found the same to be true when I was racing as well. I was fortunate enough to find this out on a dyno rather than the track. Splitfires are junk.
Old 04-09-2010, 08:07 AM
jluvs2ride's Avatar
jluvs2ride
jluvs2ride is offline
Location: Back in the Good Ole USA. South Carolina to be exact.
I saw a pic somewhere that showed a used splitfire plug, one piece of the electrode broke off and wedged between the valve and valve seat. Also showed the valve and the broken piece, you could see the impression on the valve sealing surface.
Old 04-09-2010, 08:15 AM
softail04's Avatar
softail04
softail04 is offline
from the pic your plugs look good
Old 04-09-2010, 08:21 AM
cadman311's Avatar
cadman311
cadman311 is offline
There was a story about the direction of the plug fire how well the engine will run. They do make the triple electro plugs also. Use in airplanes
Old 04-09-2010, 08:54 AM
FLUltrarider's Avatar
FLUltrarider
FLUltrarider is offline
Remember, electricity is going to follow the path of least resistance. It doesn't matter that the end of the electrode is split or not. Great marketing gimmick, but so were the traveling medicine shows. Just use the stock plug HD recommends for the bike unless you've built up some killer motor, then use the right heat range for whatever compression you built.
Old 04-09-2010, 09:20 AM
rcaddell's Avatar
rcaddell
rcaddell is offline
+1. Same thing with the Bosch +4's. One electrode is going to wear out. Whichever is the path of least resistance. It's all marketing.
NGK and Autolite have been proven quality plugs in all ICE applications for many years. And they can be had on the cheap.
Old 04-09-2010, 08:33 PM
geargrinder's Avatar
geargrinder
geargrinder is offline
The FTC (Federal Trade Commission) cracked down on the company who makes Splitfire way back in the 90s, due to unsubstantiated claims, they could no longer advertise better mileage, performance and longer life. A new sucker is born every day.
Old 04-09-2010, 09:10 PM
Ratster's Avatar
Ratster
Ratster is offline
I think what you are referring to is called "indexing". It's when you put a line on the external porcelain body of the plug that lines up with the tang on the business end. When you install the plug, ensure that line is pointing up at you after tightening. This in effect, puts the tang towards the head away from the piston. In my own worthless opinion, indexing is a waste of time. Especially when it comes to what all of us are doing. Smokey Yunick once said; You can spend your time indexing plugs, I'll drink beer".
Old 04-09-2010, 09:30 PM
HOTLAP's Avatar
HOTLAP
HOTLAP is offline
Actully we used to do this on our racing go karts but the idea is to use different thickness brass washers so when the plug is properly torqued the matal curve of the tang is toward the intake valve, that way any glowing chunk of crap on the end of the tang is away from the inrushing air/fuel mixture reducing pre-ignition.
Quick Reply: Opinion, Split Fire plugs
