front brake noise on 04 RK
Old 04-06-2010, 09:56 PM
Lindsey141's Avatar
Lindsey141
Lindsey141 is offline
Default front brake noise on 04 RK
I have a lot of swoshing sound at low speed and a squeal when braking with the front.
It's a 04 road king custom. Bought the bike used last year,.. has a total of 5,500 miles.....the pads have plenty left but the front brake squeal is starting to annoy me. Would love to have a quiet front brake.
Any help would be greatly appreciated.
Old 04-06-2010, 09:59 PM
harleydavis's Avatar
harleydavis
harleydavis is offline
Replace the pads with Lyndall Z+ pads.
Old 04-06-2010, 10:06 PM
Lindsey141's Avatar
Lindsey141
Appreciate it,..I will look into it.
Old 04-07-2010, 12:32 AM
clicker01's Avatar
clicker01
clicker01 is offline
The only think I can suggest is to go ahead and pull the caliper and clean up / inspect pads and lube pistons. You can scuff up the pads if they look glazed. Use a moly-based dry lube on the back of the pads to help dampen them.
Old 04-07-2010, 03:40 AM
Lindsey141's Avatar
Lindsey141
Thanks clicker, yeah it seems like they do not fully retract and that is what the swooshing sound is.
Old 04-07-2010, 03:59 AM
dbleagle's Avatar
dbleagle
dbleagle is offline
As you apply and then release a disk brake, it will only back off until there is no more pressure. In other words there will always be a slight contact with the rotor. Unlike old drum brakes with brake shoe return springs.
You have a free floating calipar... make sure the slide is clean and as mentioned that the pistons are not binding due to dirt/rust and the like.
Charlie D.
Old 04-07-2010, 04:18 AM
kpolak's Avatar
kpolak
kpolak is offline
The Dealer should have the moly lube in small packets (2010 catalogue) for about $4. Mine didn't know it was available.
Old 04-07-2010, 02:38 PM
clicker01's Avatar
clicker01
Anyways, let us know how it works out and what ultimately turned out to be the culprit(s).
Old 04-07-2010, 04:02 PM
Lindsey141's Avatar
Lindsey141
its gonna take a week or 2 before i have the time to look at it but i wiil repost asap with my results.
I appreciate all the responses.
Old 04-07-2010, 04:56 PM
Markymannn's Avatar
Markymannn
Markymannn is offline
As Click said, let us know what you find out. Like you I have an 04, just 7,000 miles. When rolling the bike around you will hear the rotor and pads scraping, but that I beleve to be just "contact". It doesn't bind at all. My buddy's 02 RKC does the same.
But after winter storage now, I get like a hum from the front brakes just before I stop. Pretty loud too, not a squeal. Getting embarrassing now
Quick Reply: front brake noise on 04 RK
