Torx size
1 Post
RE: Torx size
Ditto on the 25 and 27. The 27 is the bugger cause lots of people will fit the 25 in it cause it seems right and then it ends up getting stripped out. Sears has sets that have 10, 15, 20, 25, 27, 30, 40, 45.
RE: Torx size
The sizes that come with the hand dandy HD 8 in 1 screwdriver are 25,27,30, and 40. I have not found anything on the bike yet that these won't work for. These screwdrivers come in the dresser tool kit that comes with the bike, and they are about 19.00 from the HD shop.
Regards,
Bill
Regards,
Bill
RE: Torx size
What ever you do buy? get it made in the USA...the crap thats out there and it lots! will strip some and maybe? all of your hard work trying to do something right!...its worth it!
Ride Safe!
Ride Safe!
RE: Torx size
Compare prices on the -Lisle Torx Socket Set Lisle Torx® Socket Set All Torx® bits are made of heat-treated alloy steel Set comes in a convenient vinyl holder Includes: T-10, T-15, T-20, T-25, T-27, T-30, T-40, T-45, T-47, T-50, T-55, T-60 Torx® sockets Read more
RE: Torx size
ORIGINAL: TJ461vs
What are the torx sizes that are common to Harley? I want to make sure I have the right sizes.
Make sure the torx is the correct one for the bolt or screw. You would not believe how many bolts are stripped because of using a 25 on a 27 bolt.
