Screamin Eagle Mufflers and K&N air filter
If you change your stock mufflers on a 2009 Electra Glide Classic to Screamin Eagle mufflers and a K & N air filter do you know if the bikes ECM needs to be re programmed?
Welcome to the Forums! The short answer is "yes". If you are putting on Slip-ons and upgrading your air cleaner, you should get the download from HD. It will run you about a buck and a half but you need to do it.
