RPM's Vs Lugging the engine
Turned out to be a very good trade-off. I really like it.
Nothing against tachs, Every bike should come with one from the factory.
I had bad luck with the tach I bought. Apperently it was a cheapo that the needle would flutter and was hard to read. Rather than buy another one, I tried a shift lite instead. I'm big into experimenting. I've stumbled on to some great stuff that way.
I used to use one of those label makers and put a label on my tach that said "Bang!" at roughly the redline . . . subtle message to self . . . shift before here or it's gonna cost a $hit load of $ so I sorta gotta agree with the whole $hit point being at some specific RPM . . . one way or another . . .
I try not to let my rpms go below 2200-2300, unless the clutch is pulled in, as far as where I shift at, I dunno,...it all depends on how and where I am riding. If aggressive probably around 5500-6000, normal cruising about 3500, cop beside or behind me about 3000.
Chugger
Ok, I admit it. I'm a chugger. Normal riding for me is in the 1500-3000 rpm range. Geez, if I wanted to be ringing it out all the time I'd a bought a crotch rocket. That's me, just chugging along.....long live... po-ta-to.....po-ta-to......
But perhaps you're right - maybe the newer Hog tolerances are so tight that the piston can't jiggle; I can't say for sure, but it's hell on the cylinders if it does. Time to talk to some hog mechanics.
08 Heritage, 103", 54's, HPI 51mm Throttle Body,
WFO Larry Grooved heads 10.4:1,
1.90 intake & stock exhaust valves,
D&D Fatcat, SERT, VPC 83T
Evo Ind. 49t Sprocket, Hydraulic Primary Tensioner
SE Compensator, Doherty plate w/Zippers A/C
104.79HP/114.25TQ SAE DJ250i
