Anyone installed detachable saddlebag hardware, Softail Deluxe?
I'm totally frustrated with this supposedly 5 minute installation. I've installed the male posts to rear fender using lock-tite. Now my frustration- I make sure the female spring-release is positioned with slot "down" over the posts, per instructions, allowing bags to be pulled up and off after puliing back the locking spring-release. My problem is that the female (slot) must be rotating ever so slightly when I tighten it to the bags. I've even marked both the male/female and it appears they remain lined up after tightening, but, the set-up doesn't work and I have to loosen and try again. Anyone encountered this or have a suggestion? The instructions sucked so I had one of the parts guys tell me what to do, but here I am. Thanks Mark
The good news is that it sounds like you're using the same set-up I put on my wife's Deluxe a few years back. The bads news is that I didn't have any serious alignment issues! Once installed, I found that they didn't disengage easily and on one side releasing the front pin, pivoting the bag, and THEN releasing the rear worked. On the other side, I had to do the reverse (rear pin 1st). Otherwise I wasn't able to remove the bags. The fit is SO precise, that the rotation of the female slot needs to be perfect (or nearly so)....there are SO MANY jokes that could be inserted here.....but I digress. Sounds to me that tiny adjustments with trial and error will be the only thing to get you there.
I put a set of Auburn Leather saddlebags on my Deluxe using the Easy Brackets. Your description doesn't sound familiar, so I'm assuming you're not using the Easy Brackets? Like cowboy said, you'll have to give a bit more info.
Hardware was purchased from HD who got it from drag specialties I think. Anyhow, the package came with a couple extra spacers and cotter pins which I looked cross-eyed at for a couple days. That's when I took it in to Harley and the parts guy set me straight. Those pieces were for the Heritage and I didn't need. What was left were 4 male posts I screwed into the fender using my original spacers ( I have the nostalgic hard locking bags/detachable backrest). The other 4 posts have a half moon slot on the end that slips over the male, the slot must be facing down. To lock/unlock there is a spring mechanism you pull back on the shaft so the slotted end can be lifted up and off the male. The problem is, when I tighten the female to the bag, it rotates the slot just enough to throw the whole dang thing out of wack. Seems like it has to be dead-on perfect, which I haven't been able to do. I've even marked both the male/female and appears that they didn't move?
I used a set of Cycle Visions Bare Backs on my 02 Wide Glide. They had the same problem you are describing. They worked really good except one of the bags had to be taken off a certain way. You had to pull back on the release spring on the rear first, then pivot the bag forward and release the front release. It was a pain in the ***, but not enough of a pain to make me quit using them. I loved to be able to remove the bags when not in use.
I logged lots of highway miles on them and never had an issue. I'm sure the guy that bought the bike is still using them.
