if you change oil types...
Old 03-23-2010, 08:26 AM
deadbug's Avatar
deadbug
deadbug is offline
Default if you change oil types...
I am changing to redline in prim and tran from a different oil.
would you change again shortly after to avoid having 2 mixed oils or would you think the little bit left won't hurt
Old 03-23-2010, 08:28 AM
shake rattle n roll's Avatar
shake rattle n roll
shake rattle n roll is offline
I wouldent worry about that, just change it again when due for the next change
Old 03-23-2010, 08:36 AM
piasspj's Avatar
piasspj
piasspj is offline
I wouldn't worry about it at all.
Old 03-23-2010, 08:44 AM
carpetride's Avatar
carpetride
carpetride is offline
I would disassemble the tranny and clean each part, reassemble and then add the new oil.
just to be sure
Old 03-23-2010, 08:52 AM
olddude48's Avatar
olddude48
olddude48 is offline
+1 been there,never worried about it!
Old 03-23-2010, 09:06 AM
deadbug's Avatar
deadbug
deadbug is offline
Originally Posted by carpetride
i would disassemble the tranny and clean each part, reassemble and then add the new oil.
Just to be sure
right.......
casper gomez's Avatar
casper gomez
casper gomez is offline
is there a specific viscosity that you would use? is the primary and transmission going to call for the same weight?
right now i am using syn3 in all three holes, and don't like that neutral is still hard to find, and that the bike makes the really loud "clunk" when i first move from neutral to 1st. i have a buddy who is an amsoil dealer, so i can get a good price on the engine oil. it would be cool if the other two holes could take redline.
Old 03-23-2010, 09:20 AM
deadbug's Avatar
deadbug
deadbug is offline
try the redline primary case and redline transmission w/ shock proof, you won't go back
Old 03-23-2010, 11:25 AM
axnjxn's Avatar
axnjxn
axnjxn is offline
There isn't enough left to be concerned about.
Old 03-23-2010, 11:44 AM
petemac's Avatar
petemac
petemac is offline
Lots of people have done this, nothing to worry about.
Quick Reply: if you change oil types...
