if you change oil types...
Old 04-07-2010, 06:15 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
Talking
Originally Posted by carpetride
I would disassemble the tranny and clean each part, reassemble and then add the new oil.
just to be sure
And don't forget to clean the lines to and from the oil cooler along with the oil cooler especially, probably should do this at each oil change.
Old 04-07-2010, 08:10 PM
WWECOUGAR's Avatar
WWECOUGAR
WWECOUGAR is offline
Donworryaboudditt
Old 04-08-2010, 12:34 PM
Quadancer's Avatar
Quadancer
Quadancer is offline
Originally Posted by cadman311
I would like to see to do Wash DC driving with that oil very long. Hey come to rolling thunder and tell us how your oil is after that ride.
Why? I've already been through a bad traffic jam where I overheated IMO, idling and chugging along in 1st for about 45 minutes - idle pressure went to 0 and I pulled off, but the bike ran fine. Do you think there is no Amsoil 20/50 in those parades? Think again.
And my oil looked fine, actually clean after that run. (640 miles)
Old 04-08-2010, 04:05 PM
oct1949's Avatar
oct1949
oct1949 is offline
Naw,, just drain she good, fill and go..
Old 04-08-2010, 04:53 PM
RandyDowdy's Avatar
RandyDowdy
RandyDowdy is offline
Originally Posted by lh4x4
There was a shade tree mechanic way of changing to the new oil by draining the non detergent oil, fill the crankcase with kerosene and let it idle for a hour or until the temp gauge/light came on. Drain and put the good stuff in.
I did that to a 57 Plymouth 9 passenger station wagon and it worked.
I have done it on a late model truck with sticky lifters. I ran it for about 15 minutes though, I was scared of a detonation and an explosion. I saw a big block 396 blow both valve covers clear off one time. Not a pretty sight, but there was no long term damage.
Anyone remember the old technique of SWELLING PISTONS by pouring ice cold water through the carb on a V8? I never believed it, but they did run better because the carbon all turned loose, IMO.
Old 04-08-2010, 04:56 PM
Gliden's Avatar
Gliden
Gliden is offline
Default oil change
just to be sure
Your killing me...lol...and have the parts magnafluxed to check for stress cracks too......
Old 04-08-2010, 05:14 PM
Zhallart's Avatar
Zhallart
Zhallart is offline
6th Gear
CaSPER
Old 04-08-2010, 05:15 PM
MZBuckeye's Avatar
MZBuckeye
MZBuckeye is offline
Ride more, worry less.
I use Amsoil 20w50 in all 3 holes, works perfect.
Old 04-08-2010, 05:16 PM
Zhallart's Avatar
Zhallart
Zhallart is offline
6th Gear
Casper
Funny - I just put mobil 1 in my tranny and now it is EASY to get 1st. Before a bitch.
On mmy first change of engine oil to syn my mileage went up 10% I am sure !!
S C
bluharley
EVO
02-23-2014 08:07 PM
flat4fan
08-26-2011 06:37 PM
PWFD
01-10-2011 04:21 PM
starman
09-03-2007 12:18 AM
Mikeeeeeeeeee
Oil Archive (no new posts)
03-07-2006 10:35 PM
Quick Reply: if you change oil types...
