if you change oil types...
Old 03-24-2010, 10:37 AM
davey019's Avatar
davey019
davey019 is offline
I changed all 3 holes of mine to Mobil 20-50 synthetic and its really quiet and smooth shifting
Old 03-24-2010, 10:39 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Originally Posted by casper gomez
is there a specific viscosity that you would use? is the primary and transmission going to call for the same weight?
right now i am using syn3 in all three holes, and don't like that neutral is still hard to find, and that the bike makes the really loud "clunk" when i first move from neutral to 1st. i have a buddy who is an amsoil dealer, so i can get a good price on the engine oil. it would be cool if the other two holes could take redline.
Use the amsoil 75w140 SVG in your trans and the Amsoil ATF or 10w40 MCF in your primary.
Old 03-24-2010, 10:40 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Next time try the mobil1 75w140 gear oil in your trans. You will like it even better.
Old 03-24-2010, 12:11 PM
RexBuck's Avatar
RexBuck
RexBuck is offline
You will like any of the synthetic gear oils that have been mentioned Mobil 1, Amsoil and Red Line. I am now using Red Line Shockproof Heavy in my tranny (which is a 90W-250) and like it better than Mobil 1 which I liked a lot better than Syn 3. You won't want to use the same stuff in the primary though - you can use anything from HD Formula + to ATF to motorcycle oil. Do a search on this site and you will get preferrences coming out your ears.
To answer the OP, I've never experienced a problem changing fluid brands in any vehicle.
Old 03-24-2010, 01:43 PM
cadman311's Avatar
cadman311
cadman311 is offline
Red Line Shockproof in the trans. Synthetic oil in my engine. The primary 20-50 synthetic or Dino Oil.
Old 04-07-2010, 11:42 AM
Quadancer's Avatar
Quadancer
Quadancer is offline
With Amsoil 20/50 in the primary, don't expect the clunk to go away when it's warmed up fully. It clunks like it's supposed to; I just trust the Amsoil more as a wear preventative. You may also hear the chain slap a bit when upshifting; clutch engagement is magnificent.
Old 04-07-2010, 12:22 PM
cadman311's Avatar
cadman311
I would like to see to do Wash DC driving with that oil very long. Hey come to rolling thunder and tell us how your oil is after that ride.
Old 04-07-2010, 02:33 PM
hoethree's Avatar
hoethree
hoethree is offline
So a Mobil 1 solution would be:
Mobil 1 20w50w Syn in Engine Oil
Mobil 1 20w50w Syn in Primary
Mobil 1 75w140 Syn Gear Oil in Tranny ????
Old 04-07-2010, 05:32 PM
DeneFXDWG's Avatar
DeneFXDWG
DeneFXDWG is offline
I'm a little mixed up and hopefully you guys can help. I changed my fluids the other day in my new to me ride. I put Mobile 1 Synthetic in the engine, (20W-50), and Redline 75-140 synthetic gear oil in the trans, (even though I read on the bottle it says not to use it in manual transmissions after the fact), and I'm going to do the primary next.
What part of the engine does the clunking that forces people to try a different oil and then seem to think the clunk is reduced? Is it the primary or the trans that clunks and sounds gross?
Old 04-07-2010, 06:02 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
Any oil of the same API rating can be mixed and used. Oil is stupid. It does not know who made it. This goes for dino and syn mixing also.
Not mixing oil is from the 50's when detergent oil was introduced. You were not to use it in a car that had the old non detergent oil as the new detergent oil would loosen up all the sludge build up and might clog things up. There was a shade tree mechanic way of changing to the new oil by draining the non detergent oil, fill the crankcase with kerosene and let it idle for a hour or until the temp gauge/light came on. Drain and put the good stuff in.
I did that to a 57 Plymouth 9 passenger station wagon and it worked.
Quick Reply: if you change oil types...
