Electra Glide driving lights
Old 03-19-2010 | 03:30 AM
Schibes's Avatar
Schibes
4th Gear
Default Thanks
thanks for the advise, found replacements at Orielys for $8 a piece
Old 03-19-2010 | 09:02 AM
honorsdaddy's Avatar
honorsdaddy
Originally Posted by DannyZ71
That's good to know. I thought they were sealed beam lamps where you had to replace everything except the housing.
Well the older ones use sealed beams, but they switched to a replaceable bulb a while back.
If you're still using the sealed beam type, would be a good idea to change out the housings for the newer variety. The difference in output is well worth the cost.
Old 03-19-2010 | 09:03 AM
honorsdaddy
You're very welcome. I try to prevent people from paying the HD tax on as much as possible $50 for a pair of light bulbs is a LITTLE over the top.
Old 03-19-2010 | 10:27 AM
DannyZ71's Avatar
DannyZ71
Way over the top! I wouldn't pay that for the entire light assembly. Housing and bulb.
Some KC Daylighters might be cool.
Jclind1966
EVO
13
04-07-2015 04:39 PM
Steel Billet
02-19-2012 10:29 PM
TheShrink
08-25-2008 05:01 PM
TheShrink
08-25-2008 04:57 PM
Joker441
01-19-2008 01:11 PM
