Do U use front, rear or both brakes usually..
Old 03-18-2010 | 08:07 AM
cadman311's Avatar
cadman311
I have to change rear brakes every tire change. I change tires four times every year. I change front half those times. Front brakes last long as dose the tire. If I use front brake all year around with the weather in this state. I would more front tire slids. You should not use front on gravel roads, Icy roads, Wet roads, Gas stations, Dirt on roads, and in turns. Hell that every where that we ride. I use rear brake with a little front brake in most areas that I have ride. I see so many riders right out driving school crash because they teach them to use front brake over the rear brake. Some road should not use that front brake over rear brake it's something you will learn over time.
Attached Thumbnails Do U use front, rear or both brakes usually..-p6250465.jpg   Do U use front, rear or both brakes usually..-p6260526.jpg
  #32
Old 03-18-2010 | 08:19 AM
soundman's Avatar
soundman
It always amazes me to see the different riding philosophies and most of them not really based on good riding technique.
  #33
Old 03-18-2010 | 08:28 AM
cadman311's Avatar
cadman311
Go back to all the little crashes in HD forums most are from drivers using the front brakeing crash on wet roads, at gas station, on the road side and the list go on.
  #34
Old 03-18-2010 | 08:48 AM
'05Train's Avatar
'05Train
I've been told I use too much rear brake, but what the hell, it's what I do. Gotta agree that with low speed/low traction situations, you have to use your rear brake a lot.
  #35
Old 03-18-2010 | 08:56 AM
96roadking's Avatar
96roadking
Originally Posted by oct1949
I use mostly front to slow down, but both on needed occasions. seldom rear only.
How about U.??
Rear brakes only for slow speed maneuvering. Both most of the rest of the time with a heavy hand and a light foot! When I was a Newb rider, I once hit the back brake first on a wet road and went for a slide.
  #36
Old 03-18-2010 | 08:58 AM
remike's Avatar
remike
Originally Posted by ashmarc
Forgot to actually answer the question.....
Both......unless in bumper to bumper traffic (about 5-20 mph, then front only).
Really?
  #37
Old 03-18-2010 | 09:40 AM
Brood's Avatar
Brood
The only time I use the rear exclusively is to 'trail brake' on corner approachs if think I'm coming in too fast.
...hmm, I need to get a sig pic going. To bad I'll be riding all day and won't have time.
  #38
Old 03-18-2010 | 09:43 AM
happyh99's Avatar
happyh99
I use both most of the time. I try to give the rear a pump or two first just to get the brake lights on and then ad the front.
I know that hitting the rear first is leftover from riding bicycles as a kid and faceplanting from using only the front brake. Some lessons stick with you whether you need them or not.
  #39
Old 03-18-2010 | 09:49 AM
will2002's Avatar
will2002
I carry an anchor on my bikes that I just throw out when I want to stop.
  #40
Old 03-18-2010 | 09:55 AM
ftanner's Avatar
ftanner
I use both to stop. Rear only to just slow down when I want to go around a corner. Front only to just slow down when I am going in a straight line.
Quick Reply: Do U use front, rear or both brakes usually..
