Rear signal lights to brake light conversion problem
Old 03-17-2010, 10:44 PM
ashmarc's Avatar
ashmarc
ashmarc is offline
Originally Posted by foxhd
I think it is due to a dot law because the blinkers are too narrow or close to the brake light and therefore not road legal.
Pretty darn sure you are correct here.....
Amber signals do not have a minimum distance to the tail light...
Red tail light/red turn signals have to be a certain distance apart to distinguish between the lights....
Can't seem to Google proof, but pretty sure this is correct.
Old 03-21-2010, 08:03 AM
foxhd's Avatar
foxhd
foxhd is offline
Here is an interesting note...The modules are probably all the same. The difference appears to be in the lens supplied with the module. I just bought the module for sportsters and softails as it has the small red lens'. It was a direct plug in. It works fine on my 09 streetglide. Made me a happy camper....thanx, stamper.
Old 03-21-2010, 11:54 AM
Racer99's Avatar
Racer99
Racer99 is offline
Does anyone know if they make a dual setup type device? Other words, one Module to make your turn-signals and brake lights into one to INCLUDE them to have a Blinking brake light (i.e "Back-Off" Brake Light Signal Module)?
Or..do you have to purchase two separate modules?
straightleg
02-23-2011 11:53 AM
Windup08
09-30-2007 04:01 PM
PriestFan
08-02-2007 07:09 AM
Angry_Inch
07-19-2006 12:31 PM
ptoemmes
06-16-2006 04:50 PM
Quick Reply: Rear signal lights to brake light conversion problem
