Converting to 200 rear tire, help?
Hey, anyone have any info or pics of someone turing there 05 or older softail/night train into a 200 tire? i kno heartland sells the ez 200 but thats for bikes with the 200 tire already, i want to convert my 150 tired night train to a 200 tire? any kind of info would be awsome thanks!
"Phatail Conversions"
what does it mean to cut the frame horns? those other kits are way out of my price range! kinda of crazy, i found one kit that requires you cut the frame horns but im not quiet sure what that means?
you will need an 07 night train belt and pulley! the narrower ones that came out that year to accomodate the 200,you will need the wheel off the 07,as well as the fender and struts,you may have to grind the brake tab a little!
i put an 18x5.5 on my deuce but am only running a 180 at the moment,fits easy,for me to go to 200 i will need the narrower belt and pulley note:the deuce can run a 200 with factory fender, you cannot
thatd be a hell of alot easier! i dont need a longer 5 gear shaft to replace the old one or anything like that? i was thinkin about runnin the stock 06 and up fender with a rear spoked black crossbones wheel, i think it would look pretty bada**, thanks for the help man
DarrelRodman
10-28-2022 01:01 PM
