96 inch stroker question
We all know that the 88 inch engine was upped to 96 inches by increasing the stroke. Now its always been known that if you increase the stroke you get more power / torque, but the down side has always been that a stroker motor sacraficed longevity. So now the MOCO compensates by adding a 6 speed tranny so that the motor is turning less RPM's in 6th gear but 6th gear is only good above 70mph. If you are doing other than expressway driving you will be in a lower gear and that motor will be pounding itself to death. Correct me if i'm wrong................BG
RE: 96 inch stroker question
Where did you hear that a stroker motor sacraficed longevity??? a motor is a big ol air pump, if built right it should be ok..How many miles do you want it to run?? how many years?? I'm quite sure that if I had a 96 incher I wouldn't worry about it..now?? some of the after market big inch motors, I have heard horror stories about them.. go ride it and stop worrying about it.[sm=biker.gif]
What strokers sacrifice is top RPM for low RPM grunt (no pun intended). The 96s are also supposed to have lighter parts, and that helps on rotational stresses.
For example, the Chevy 302s (327 motor w/283 crank) were prized for their rev-ability - good for road courses. Whereas 383s (punched 350s w/400 cranks) were for torque and wanted by draggers/muscle cruisers.
ORIGINAL: Bear64
I am still happy with my TC88 but I wouldn't be a bit worried about the TC96 either.
Kevin
APOCALYPSE
04-23-2008 06:21 PM
