Changing out wheels - 3 hours labor?
Old 02-26-2010, 06:35 PM
geezer glide 56's Avatar
geezer glide 56
geezer glide 56 is offline
New wheels don't come with bearings...Just installing the bearings and putting the rotors on the front wheel would be about .8 hrs. That isn't even including removing the old wheel the old tire from the old wheel and reinstalling it on the bike.
Old 02-27-2010, 07:45 PM
CroK's Avatar
CroK
CroK is offline
Or reshimming the bearings PROPERLY. Anyone that puts new bearings in, or uses the old ones for that matter, without checking the thrust in the axle/bearings is cuttin corners...
Old 02-27-2010, 11:49 PM
Spartacus55's Avatar
Spartacus55
Spartacus55 is offline
Just did the chrome wheel swap on 07 rk plus new michelin commander tires mount and balance tires and install wheels 2 front rotors and 2 ***** shiny wheel spacers 300 bucks at dealer who charges 90 bucks an hour this comes out to 3hours and 15 minutes labor for the whole shabang 3 hours per wheel is ludicrous.
Old 02-27-2010, 11:52 PM
Dan1127's Avatar
Dan1127
Dan1127 is offline
Stealerships! 1 hour per wheel only.
Old 02-28-2010, 07:13 AM
geezer glide 56
And how do you know this?...It is one hour to change just the tire...That doesn't count replacing the bearings and swapping the brake rotors and the pulley to the new wheels.
Old 02-28-2010, 08:00 AM
hardwork2's Avatar
hardwork2
hardwork2 is offline
If you were in Ky I would take them off and put them on for nothing. I can't believe all the harley riders have not volunteered to give you a hand. Whats a couple hours to help a girl out.
Old 02-28-2010, 08:16 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 9,403 Likes on 5,006 Posts
Originally Posted by oct1949
Thats probably what the book say's...
not what it really takes...
of course they charge by the BOOK....
Its,,,, All about the $$$$$$
Of course it is about the $$, they are in business to make a living...
Old 03-01-2010, 01:09 AM
HarleyGirl76's Avatar
HarleyGirl76
HarleyGirl76 is offline
That's really great of you... It's not that I don't want to pay a fair price, just wondering. Anyway, should have the bike back. Of course they talked me into chroming everything else and polishing the rotors. I'm really looking forward to gettnig it back sometime in the next few weeks.
Old 03-01-2010, 01:51 AM
kiwideuce's Avatar
kiwideuce
kiwideuce is offline
man you live in a dream world!! my new wheel came with bearings,i only just changed my wheel from standard to 18x5.5,changed rotors over,pulley, and even changed out the hub,hub 55lbs,rotor 40lbs pulley 60 lbs,all torqued down,i had a new tyre put on the rim earlier,fitted and balanced 10 mins,took me longer to choose the tyre!took me less then an hour and that is changing to different from standard,i did do the mock up a week earlier to get measurements for the new hub to be machined 13mm, and measurements for new axle spacer,then put original wheel back on to ride while i was waiting for machine shop!! i havent taken rear wheel of many times,these guys could do it in there sleep and be heaps quicker then me and air tools! probably less then half hour
Old 03-01-2010, 04:45 AM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
wcsj55@yahoo.com is offline
The whole job should be about 3-4 hours!!
R&R wheels
Install wheel bearings
Install valve stems
R&R tires and balance
R&R brake rotors (3)
R&R belt pulley
Adjust belt
Check brakes
Test ride
Quick Reply: Changing out wheels - 3 hours labor?
