Is it reasonable to expect my indy.....
Old 02-26-2010 | 02:01 PM
woodworking1's Avatar
woodworking1
UPDATE
I re tourqued the head bolts yesterday. I seemed to work...kinda. There was no oil coming from the gasket while the bike was running, but there is definitely oil there now. It is supposed to be in the 40's this weekend. I think I will take it for a nice ride and see what happens.
Old 02-26-2010 | 02:42 PM
Faast Ed's Avatar
Faast Ed
Originally Posted by woodworking1
They replaced all the gaskets in the rear cylinder last May and everything seemed fine. I really don't understand why it just started like that. The more I think about it, I did find a puddle after a ride last summer but thought it was the tappet cover because that's where it looked like it was coming from. I thought I fixed it and don't really recall having an issue after that.
But honestly, I never saw it leak like the way it did Saturday when I started it up. I let it get nice and hot to make sure it wasn't just cold and leaking. It leaked the entire time it was running and continues to still seep.
BTW-- Before I took it to the indy, my bike never leaked oil.
Two heads gaskets and now a base gasket.
Do you let your bike get nice and warm before riding it hard?
Old 02-26-2010 | 02:45 PM
Faast Ed's Avatar
Faast Ed
UPDATE
Clean it thoroughly with some Brakeclean before riding it.
Less chance of being fooled by old oil.
Old 02-27-2010 | 12:08 PM
woodworking1
Faast Ed the first 2 head gaskets were a result of an ignition coil issue. One was completely blown and the other was just smoked. In the past, I had not let it warm up enough before riding. Since my "enlightenment" I now let it warm up completely before riding hard. I do ride it hard, but not that hard! I am sure that it is not "old oil". It is leaking less that before I re tourqed, but none the less, still leaking.
I am fearing the bottom of the cylinder is warped. I will take it for a ride and see if it worsens or what. If it persists, I will pull the cylinder and take it to a machine shop for inspection.
I will say that the head bolts seemed really tight. Is it possible that they might have been over tourqed and damaged the gasket?
Old 02-27-2010 | 12:48 PM
Faast Ed's Avatar
Faast Ed
The proper torque is meant to allow for expansion and bolt stretch. (Thus the importance of a good warm up). You want everything fully expanded before putting the high rpm's on those head gaskets.
Overtightening likely wouldn't hurt the gaskets but it might cause some other problems. Depends on what type of gaskets and mating surfaces. You can kill some gaskets by over tightening but I doubt that you can with base gaskets. (Speculating there).
You should be able to ride hard. I ride real hard sometimes. But not unless I've been already riding softly for a half hour or more (preferably more). Nice and completely warmed up.
You very well might have some warpage and it's a good plan that you have (to check for that). Can't blame the Indy for that either.
I use Comtic head gaskets. Dang near impossible to blow. 42 ft lb torque, step up in graduated steps.
Old 02-27-2010 | 01:48 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
One question: Are you using the correct head bolt tightening procedure as outlined in service manual? Here is the excerpt from my 2005 XL manual:
The procedure for tightening the head screws is critical
to proper distribution of pressure over gasket area. It
prevents gasket leaks, stud failure, and head and cylinder
distortion.
10. See Figure 3-67. For each cylinder head, start with bolt
numbered one, as shown. In increasing numerical
sequence (i.e. – 1, 2, 3, 4), tighten head bolts in the following
steps:
a. Tighten each bolt to 96-120 in-lbs (11-14 Nm).
b. Tighten each bolt to 13-15 ft-lbs (18-20 Nm).
c. Loosen all bolts.
11. After head bolts are loosened from initial torque, tighten
bolts in three stages. Tighten in increasing numerical
sequence (i.e. – 1, 2, 3, 4), as follows:
c. See Figure 3-68. Mark cylinder head and head bolt
shoulder with a line as shown (View A).
d. Tighten each bolt an additional 85°-95° (View B).
12. Repeat above procedure for other cylinder head
Old 02-27-2010 | 01:51 PM
KBFXDLI's Avatar
KBFXDLI
BTW, you can find a copy of the 05XL manual here: http://www.sendspace.com/file/h952ae
booze hound
EVO
04-12-2019 06:22 PM
avnsteve
11-12-2013 09:05 AM
J DOG
Exhaust System Topics
13
06-04-2010 06:57 PM
vindyl
08-03-2008 09:56 AM
rontech
02-21-2008 07:40 PM
Quick Reply: Is it reasonable to expect my indy.....
