Notices
New HD code reader?
Old 12-04-2010, 02:09 PM
oct1949's Avatar
oct1949
oct1949 is offline
Not sure why I'd want one...
What would be the advantage of it.?
It says be prepared for when U go in for a service,, Ugh, then why have it, just let the wrench use his if there's a problem.
Old 12-04-2010, 02:10 PM
p51bombay's Avatar
p51bombay
p51bombay is offline
If you have or plan to get a tuner - TTS will do all that thing does and way more.
Old 12-05-2010, 06:14 AM
IndyClassic's Avatar
IndyClassic
IndyClassic is offline
Goodness p51, do you have stock in Mastertune? Just kidding.....
I started this months ago when I found it and posed or meant to pose as a "for those of us that do our own work, might this be a speedy/helpful tool?" question. Admittedly I did not really ask it that way originally and have not purchased one yet either. Too many other things in line above it.
I run a SEPST on one bike and PCV on another. In my case I was pondering if it would be a tool for my work (do not go to dealer) and not looking for a different tuner.
Old 12-05-2010, 06:30 AM
FroggyFatBoy's Avatar
FroggyFatBoy
FroggyFatBoy is offline
will it give you live sensor data ? if you have a few bikes and want to do more than read codes and do some actual diag it would be a good tool to have. if all you're gonn do is pull codes then the manual way is just fine.
i'm surprised that bikes with feedback efi doesn't fall under the fed law of all vehicles using the same diag connector, basic fault codes and descriptions be standarized.. OBDII
Old 12-05-2010, 12:54 PM
Bluehighways's Avatar
Bluehighways
Bluehighways is offline
Q: Will it read live sensor data?
A: No
Other: It reads codes and the name of the code, and it clears codes. It's not a Scan Tool.
Bluehighways
04-19-2012 01:46 AM
Bluehighways
03-12-2012 01:59 AM
Xzotik
04-21-2011 06:27 PM
Bluehighways
03-19-2011 12:33 AM
makstv5
03-18-2010 09:35 AM
Quick Reply: New HD code reader?
