Notices
Washing White walls.
Old 02-06-2010, 08:06 PM
shortride's Avatar
shortride
shortride is offline
I hear a lot about Wesley's WW cleaner but I've been using Simple Green for a while and it does a great job as long as you clean the WWW often. The little narrow WW tires on my Ultra Classic is so small, it just as well could have been a Blackwall tire.
Old 02-06-2010, 08:11 PM
krazy3's Avatar
krazy3
krazy3 is offline
Originally Posted by SleeplessinVegas
1. Wesley's WW cleaner, at most auto parts stores.
2. SOS Pad and Elbow grease
That's what I always did.
Old 02-06-2010, 08:44 PM
El Rey's Avatar
El Rey
El Rey is offline
Wesley's is pretty harsh on white walls, leaves a lot of cracking and pitting.
Try, soap and water when you wash you bike, then use the magic Erasers and wipe dry with clean micro fiber towel.
Mine stay "new" this way.
Old 02-06-2010, 08:48 PM
cchips's Avatar
cchips
cchips is offline
WD-40 works great, & not it does not make your tires slick.
Old 02-06-2010, 09:45 PM
Juve996's Avatar
Juve996
Juve996 is offline
Paint thinner, works like magic..
Old 02-06-2010, 10:33 PM
NursePhoenix's Avatar
NursePhoenix
NursePhoenix is offline
Cycle Care wheel cleaner and a brass brush
Old 02-06-2010, 10:46 PM
Whiskers's Avatar
Whiskers
Whiskers is offline
No one's mentioned a motorcycle jack...essential - it cuts your time in half when washing the WWW's.
Old 02-07-2010, 01:00 AM
Silver Fox's Avatar
Silver Fox
Silver Fox is offline
Mean Green and minimal elbow grease.
Old 02-07-2010, 01:08 AM
DZLDR's Avatar
DZLDR
DZLDR is offline
I found out today (by mistake, grabbed the wrong spray bottle) that TILEX with soap scum remover works like a charm! Man my wide white walls were dirtier than the floor at the local Wal-Mart. Sprayed the whitewalls getting ready to wash the bike, and the dirt and crud just started sliding off. Really didn't even have to scrub!
Old 02-07-2010, 01:28 AM
RBJones's Avatar
RBJones
RBJones is offline
Bleche-white and steel wool. Let the cleaner sit for a few minutes to give it time to break down the oils.
Quick Reply: Washing White walls.
