Patriot Defenders Exhaust!
This exhaust seem to have the ideal solution ! Has anybody seenm them / heard etc? Seems like the idea solution of you like the loud sound but can switch over if in an area that could cause problems with police etc
http://www.youtube.com/watch?v=0Y-Koxn9FZ0
http://www.pertronix.com/prod/harley...s/default.aspx
450 dollars as well - not bad
I've heard that the butterfly systems in those kind of pipes get rusted up after a while and become hard to work or wont work at all. No first hand experience though, but a good idea none the less.
there is also a company in Holland but they are very expensive http://www.jekillandhyde.eu/site/ind...dex&cPath=2_36
Looks like a fantastic system though
bump - I'd like to hear about actual experience with the butterfly valve after owning / running the pipes for some time (1+ year). Have heard great things about the pipes when first installed, but nothing down the road, so to speak.
Anyone care to share their experience?
Been running the Peacemakers which have the butterfly valves at the front of the mufflers for about 3 years and haven't had any problem with the valves. The motor in the actuator went out last fall - had to replace the whole actuator unit. Started blowing fuses after that. Tried everything I could to fix the fuse problem - would get it to play nice for a bit then pow another fuse. Ended up taking the old actuator and converted it to manual operation.
The Peacemakers are slipons and you keep the stock headers.
I like the push/pull cable setup on the Patriot. Don't care for the 2 into 1 setup. Not sure about the butterfly being at the back end.
