Notices
How many miles on Amsoil??
Old 01-21-2010, 01:28 PM
legacycycles's Avatar
legacycycles
legacycycles is offline
Oops
Originally Posted by DoubleJ74
From the Amsoil website:
SERVICE LIFE
Recommended for use up to twice the motorcycle manufacturer change interval (miles/hours) or one year, whichever comes first, in engines, transmissions and primary chaincases. For Big Twin Harley-Davidson transmissions only, follow the Harley-Davidson recommended drain interval for synthetic oil of up to 20,000 miles or one year, whichever comes first. When using an engine filter other than AMSOIL Ea, change the filter at standard intervals.
Very good,H-d Standards Are 2500 Miles Engine oil....5k Primary and trans. So following My earlier post.....5k on all compartments....If you want to run more,take a sample of the oil and send it to amsoil,they will in turn tell you to continue using or Change it....Do we really need to keep beating a dead horse here?
Old 01-21-2010, 04:31 PM
oct1949's Avatar
oct1949
oct1949 is offline
Most riders don't even put 10k a yr on their bike so they should be changed at least once each yr.
I have a couple friends that change all three and filter @ 2500 miles on their 88's with dyno oil..both of them have over 40k on theirs and nether have had issues. other than tensioners.
My 96 manual says change 5kmotor, 10kprimary, 20ktranny, even with Syn oil.
The first 4 changes I did all three every 5k, but the last one toward the end of last summer I just did motor...only put 8k on her last yr.
changing the motor at 5k, then changing the primary every 5k, and the tranny at 10 would be 1/2 of what the MOCO recommends on these two. Could go longer and probably be ok, but I and others just don't because the Air cooled can be harder on the oils.
Elwaupo
03-12-2017 01:22 PM
wilddave
09-10-2015 02:03 PM
TWIN CAM 96
Oil Archive (no new posts)
04-07-2011 06:39 PM
Bluesrider
06-09-2007 07:24 PM
Phantomryder
06-01-2005 05:46 PM
Quick Reply: How many miles on Amsoil??
