i'd like inputs on this throttle lock rig
Old 01-07-2010 | 10:27 AM
goo's Avatar
goo
Default i'd like inputs on this throttle lock rig
i got a soft tail xbones,
thx, goo
http://www.brakeawayproducts.com/
Old 01-07-2010 | 10:37 AM
JaronB's Avatar
JaronB
Old 01-07-2010 | 11:24 AM
tejasrider's Avatar
tejasrider
thx, goo
I am not a fan of throttle locks, but this one looks ok with the brake release, but at $219.00, Ithink I will pass.
Old 01-07-2010 | 11:43 AM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
Hds have throttle friction adjusters that work fine for me. When I ride w/others that are on metrics they always wanty to know how I can ride and take my hand off the throttle.
Old 01-07-2010 | 11:44 AM
BoomerBob's Avatar
BoomerBob
Sorry, no personal experience with the one in question, but I do have experience with a couple of others.
Throttle Tender - Decent inexpensive way to lock the throttle on the straights. I use one on my Softail. I have it turned to the inside of the throttle cables since I don't use it often.
SAC Cruise Control Grips - My personal favorite. Easy to use, holds the throttle, and looks good. I use this one on my EG.
Old 01-07-2010 | 09:27 PM
harleydavis's Avatar
harleydavis
I have the Breakaway and liked it much better than the standard throttle lock screw. However, I switched to Kuryakyn ISO grips and the Breakaway wouldn't fit. It wasn't quite as expensive when my GF bought it for me.
Old 01-07-2010 | 09:47 PM
Rabbit_'s Avatar
Rabbit_
Have you looked at Kuryakyn's Electro-Magnetic Cruise Assist. Might work better.
Old 01-07-2010 | 10:42 PM
baucom1's Avatar
baucom1
I had the break-away on my Roadstar and really liked it. It is very clean looking installed. I installed the Kury electro magnetic on my wifes Deluxe and she loves it. The only thing with the Kury is it takes up quite a bit of room. You either have to get turn button extensions or reach for the turn buttons
Doug
Old 01-07-2010 | 11:04 PM
phat96's Avatar
phat96
Got mine for Xmas and install was pretty easy, used dish soap and it slid right over my Kuryakan grips, with a little pushin. so far so good, it locks on desired speed and press the release or hit the brakes and it releases. I'd give it a thumbs up, only part is it won't hold the speed on upward slope.
ije
04-14-2014 08:47 AM
hasten21
06-17-2013 09:40 PM
bigdaddy33
10-01-2011 06:00 PM
stephenabel
12-19-2010 08:09 PM
WarBootie
07-29-2009 10:03 AM
Quick Reply: i'd like inputs on this throttle lock rig
