Notices
Engine warm-up time
Old 12-28-2009, 10:57 AM
TequilaJohn's Avatar
TequilaJohn
TequilaJohn is offline
Actually, if your engine does not have any special considerations for warm-up, it's best to ride it for the warm-up. Here's a good article on the subject.
http://www.americanrider.com/output.cfm?id=1021933
Old 12-28-2009, 12:37 PM
Kumite's Avatar
Kumite
Kumite is offline
Thanks John...good article.
R. Todd
Old 12-28-2009, 01:26 PM
oct1949's Avatar
oct1949
oct1949 is offline
When new I was told to wait till U feel a little heat in the rocker boxes with Ur finger. bout 2mins in the summer on first ride of the day.. and not to wind her out till fully warmed up. bout 10 miles...
This will let all the metals expand and seal.
Heard but never seen that nailing a cold or not warmed up motor can blow top end gaskets....So I don't chance it, takes Grandma that long to settle in anyway.....Ha.
Old 12-28-2009, 01:55 PM
BigGdawg's Avatar
BigGdawg
BigGdawg is offline
I vote for this way and I do likewise. Both mine are Twinkies.
The one with a carb I give a little slack - about 30 seconds.
Old 12-28-2009, 02:16 PM
clicker01's Avatar
clicker01
clicker01 is offline
+1 Makes sense; Thanks
Old 12-29-2009, 12:51 AM
Alter Kaker's Avatar
Alter Kaker
Alter Kaker is offline
Senior Rider
Default Warming up
I paid careful attention to the AmericanRider article. Thank you.
One of the things I noticed was that Joe Milton mentioned the particular problem with carburetor fed engines. We all know that the FI mills have a much tighter control system.
But, thank you. I now understand where the various opinions come from.
Old 12-29-2009, 07:12 AM
TequilaJohn
Yeah, the EFI's are much better at metering the gas feed on cold starts, but even then they still provide a richer mix on cold starts and the same principles still apply. The longer your bike runs "cold", the harder it is on the engine, as they are designed for optimum clearances and function at operating temps. Running your bike moderately (as in riding it thru normal shifts, without lugging or over revving) during warmup will get everything up to operating temps faster/safer than idling. All that being said, these beasts aren't pieces of fragile china, and letting them idle while ya pull on your gloves and jackets ain't gonna do 'em in. Just purely technically speaking, a moderate ride is better for warm-up than an extended period of idling.
Old 12-29-2009, 01:04 PM
oldairboater's Avatar
oldairboater
oldairboater is offline
I have seen a dumbass bend a valve---he got on a cold bike. Hammered it--missed a shift and hit the rev limiter. He might have bent the same valve on a hot engine but then again maybe not. I have never understood how or why someone would stress a cold engine with different metals that expand at different rates when hot or cold.
Old 12-29-2009, 04:39 PM
WWECOUGAR's Avatar
WWECOUGAR
WWECOUGAR is offline
I let mine warm up for a few minutes even when the weather is warm. Longer when it's cold. Mine is EFI. I know I don't have to do this. I don't think it matters either way if you take it easy for a bit everthing should be fine.
Old 12-29-2009, 08:50 PM
gasol1ne's Avatar
gasol1ne
gasol1ne is offline
My belief is 2 to 3 minutes is fine for these air cooled engines, even in colder weather. 5 minutes seems too long, but probably won't hurt. Strapping on a helmet and gloves can take two minutes...
IRON1250
EVO
39
10-14-2021 12:37 AM
joshoid
06-12-2012 02:21 PM
Striker951
03-19-2012 11:31 AM
RodeoHard
EVO
02-22-2011 03:22 PM
Quick Reply: Engine warm-up time
