cam with c stamped on lobe??
ok,new to forums,
trying to get you guys to give me some info.
got a 90 evo im rebuilding stock to
put in chopper.
Its bored 20 over with new hd pistons,ect.
headwork,ect.
I got a hd cam with a letter c stamped on the lobe and 2 groved
circles around gear.
What cam do i have,is this a california emmission cam or what.
I know i can put better cam in and all of that but just wanted to go back with a stock cam.
I think they made 2 or three cams in that area.
lower 48 cam and a california cam.
need help
evo rebuild rookie.
ps: I do have a revtech 30 cam but i think its not a bolt in cam,I just need a little advise
thanks
put in chopper.
headwork,ect.
need help
evo rebuild rookie.
thanks
Drop in a bolt in cam now. It's a cheap upgrade that you won't regret. My two favorites are the Andrews EV3 ( some folks like the 13) or the S&S 502. That cam rocks!
Shu is on it.....
http://www.truettandosborn.com/tech_tips.htm
Using the Andrews cam numbers, you might want to run a J grind, ... you can run a more aggressive cam like the Andrews C grind. .... First the obvious differences between the Shovelhead and the Evo: ... The engine ain't dead by any means, and is considered by many to be the best motor Harley Davidson ever made.
Thanks for the info everybody,here is picture of cam,I bought it for pennies,I was told it was a stock hd cam,Im gonna invest in a ev 3 or ev 27 and move on with my engine.
90evo
happy hollidays and spring is comming somday!!!!!!!!
90evo
In 1990 the Ca. bikes had a different cam than the other states.
I had a Ca. 90 FXRS-Conv. I immediately changed the cam. Big difference.
