stick on reflectors
I used fishing line to remove the front ones. Slip it in behind them and kinda saw it back and forth. It was still hard to get off but it worked. Then I used a rag and some WD-40 to remove the leftover residue. It took me awhile but I did get it all off. I never removed the ones from the fender because I was afraid of screwing up the paint.
When I take off the stickers, I use fishing line and a hair dryer. If you warm up the sticker, the glue softens and the fish line works better. Then you use WD-40 or rubbing alcohol to get the rest of the glue off. I took a bunch of them off my last scoot and it worked great.
heat them up with a hair dryer or heat gun. run some good thick fishing line behind them (do not try to pry them off, unless you use something plastic to do the prying). Then use the wd40 to take off any leftover glue residue. 20 min job tops
