adapting a 2000 Fat boy rim to run on a 1996 bike ??
Old 12-20-2009 | 08:06 PM
blair's Avatar
blair
Default adapting a 2000 Fat boy rim to run on a 1996 bike ??
I have a line on a set of crome Fat Boy rims off a 2000. What are the changes needed to be made to make them work on 1996 . I know in 2000 the rims were changed . pre 1999 the rims had 3/4 Timken bearings and seals . Has any one made this change , that could tell me whats involved.
Old 12-20-2009 | 08:17 PM
tlb's Avatar
tlb
you should be able to buy a 3/4 inch bearing
Old 12-20-2009 | 08:30 PM
harleydavis's Avatar
harleydavis
The 2000 Fatboy wheels run 3/4 inch sealed bearings vs. the Timken in the 1996. If your bike is a Fatboy, then switching out the wheels shouldn't be a problem since you have a 3/4 inch axle. Check the bearings in the 2000 wheels to make certain they are good, or replace them if needed.
Old 12-20-2009 | 08:34 PM
franklin322's Avatar
franklin322
the bearings are the only difference i belive you will need the pulley for the 2000 wheel also
Old 12-20-2009 | 08:36 PM
blair's Avatar
blair
They are going on 1996 Dyna Wide Glide (just the rear) my axels are 3/4" .So your telling me that the only difference between them is the bearings ?? how about the spacers ??
tlb's Avatar
tlb
Off the topic, what year did they switch to a 1" axle?
Old 12-20-2009 | 08:46 PM
harleydavis
Yes, just the bearings are different. However, you may need to put the wheel on the Dyna to check the spacer fit. Otherwise, you may need to buy different spacers, or cut/modify new ones.
Old 12-20-2009 | 09:03 PM
blair's Avatar
blair
thanks man thats what I want to know
Roc2000
12-28-2013 08:28 PM
92Ranger
10-06-2013 11:48 AM
fast99
03-13-2013 11:39 PM
blair
04-12-2010 08:10 AM
dirtyharry
12-28-2008 08:30 PM
Quick Reply: adapting a 2000 Fat boy rim to run on a 1996 bike ??
