Quick Oil Change Question...Please Bear with me!
Old 12-17-2009, 07:32 PM
dFREDb's Avatar
dFREDb
dFREDb is offline
Default Quick Oil Change Question...Please Bear with me!
Raining out with no let up in sight. Can you just idle the engine 4-5 minutes til it gets to operating temp, than change the crankcase oil? It's just a little past due, and I can't just sit here and watch the junk on t.v.! If not I'll just wait til tomorrow evening and run it 5 0r 10 miles if the weather lets up, or just suit up for the ride. Hate to get the dang thing all muddy if I don't have to. Thanks for the help! Frederick
Old 12-17-2009, 07:41 PM
dennyo's Avatar
dennyo
dennyo is offline
Received 1,059 Likes on 633 Posts
_______ Yup , Idle will Work
Old 12-17-2009, 07:47 PM
jimmers1817's Avatar
jimmers1817
jimmers1817 is offline
Personally I wouldn't worry about warming up the bike. You're leaving several ounces in it anyway. If you do heat it up be careful around those hot pipes. They leave permanent tatoos.
Old 12-17-2009, 07:51 PM
dFREDb's Avatar
dFREDb
dFREDb is offline
Thanks all. I was just wondering if its more beneficial to get the contaminates suspended in the hot oil so you can drain most of them out. I would guess that they collect at the bottom of the pan anyway hot or cold.
Old 12-17-2009, 07:56 PM
nighttrain72970's Avatar
nighttrain72970
nighttrain72970 is offline
I usually warm mine up before draining the oil. And take out the dipstick when its draining. It seems to get a little more oil out of it by letting air through. JMO
Old 12-17-2009, 08:00 PM
2kids3pets's Avatar
2kids3pets
2kids3pets is offline
While were on the oil topic again has anyone considered flushing the bag perhaps with a oils gas mix...just to clean it out
Old 12-17-2009, 08:07 PM
hogginit's Avatar
hogginit
hogginit is offline
Gas may not be a geat flushing agent. I would think that the fumes could possibly be explosive especially when it is first started after replentishing oil.
Old 12-17-2009, 08:11 PM
2kids3pets's Avatar
2kids3pets
a 50 50 mix and you wouldn't start the bike...its just to flush the oil tank
Old 12-17-2009, 09:31 PM
hatchetman's Avatar
hatchetman
hatchetman is offline
Sea foam is safe & you can run 1 oz per gallon of oil to flush your whole motor. it re liquifies dried up deposits so they can be trapped by your filter.
if you just want to rinse your tank, I would use diesel or kero.
Old 12-18-2009, 03:31 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,844 Likes on 1,084 Posts
A little Kerosene is way better than gas
Quick Reply: Quick Oil Change Question...Please Bear with me!
