Harley with a Chevy Corvair engine
Harley Kick
I've seen Harleys that would throw you over the handlebars also when the timing was a little off. Hurt worse than a hog bite when that thing raked you up the side of the leg when it kicked back also. Thank god for electric start
Great Links
Very informative, I like to read this stuff, and love the concept of competitive bidding for procurement! I bet the R&D and testing was all on the MOCO's dime also.
Now its no bid contracts and cost overruns, getting stuck with stuff that don't work. Them were the days, and those were some interesting bikes!
Thanks for the link
No $hit! I'd like to see an Ultra with that engine. Could you imagine cruising buy a Gold Wing gathering with that!
No reason it should be hard to kick start. Using flibuoy's stats, a 164ci engine divided by 6 cylinders works out to 27 1/3 ci per cylinder. A 96ci Harley v-twin works out to 48ci per cylinder. Assuming similar compression ratios, it should be easier to get a cylinder to light off.
I'd like to know how he mated a kick starter to a car engine in the first place.?! It is an impressive conversion!
Ride Safe,
Steve R.
