Is my new tire too close to my fender?
After reading that post, I was thinking about the same photos
I have drawn a conclusion on this whole setup finally. I have not ahd a 150 tire with my DNA whels until now. I guess the hub is different than the sock wheel hub. It took me long enough to figure out why there is a situation with this. Anyway, a freind is coming and we are going to sort this out today.
Annie, THIS thread is starting to run up, on the "Bike in the Truck Box" thread. Some FUNNY chit in that one, too. Peeps are jus' FULL o' GOOD (???????????????????) advice !!!!
Wouldn't a "salad shooter" work better than the cheese grater?
Dammt, people, THEY make POWER toolz, to do some of this chit !!!!! Jeesh.
Better yet, jus' git some of these wimmin to ride on the back. They can "grate" on yur nerves pretty good, let 'em "chew" on that tar, for a while !!! PROB solved !!!!
I just realized why the 150 does not fit. This is a different wheel than I had the other 150's on. D'oh! Salad shooters are great. But I was thinking a garden weasel might do better.
One of the things you have to keep in mind when adjusting where the belt is from the swingarm, is the angle that it goes into the primary pulley. Also, the brake caliper is mounted on the wheel axel so you shouldn't have a problem there that can't be corrected with spacers on the axel. As far as shaving the tire down, it would seem that sandpaper or a belt sander would be better that a gouging action of a cheese grater file.
Ginzu knife? Thanks for the response. I think we are going to try the tug the fender method first. I think my primary pulley is 2" wide which leaves room for the belt with different spacers, but easier method will be tried first. Thanks.
Your stock fender is wide enough for a 150, barely, but it is if you get everything spaced even enough on both sides... worst case; some nuts or bolts inside the fender may have to be ground down some - (I had to do that on an FXR).
It doesn't matter if your clearance is 1/8"in. or 1/4. Enough is enough - c l e a r a n c e is clearance. 1/16th might get you a scrape when the tire flexes on a big bump and perhaps you can't ride a 300lb bride, but if it isn't scraping on normal rides , I wouldn't worry about it.
