Batt. Tender- to use or not to use, that is the question.
#41
Most newer bikes have a milliamp draw from the ECM, radio, regulator and security system. A float type charger like a Battery Tender will prevent battery drain.
#43
Agreed, however, at the moment, not a whole lot I can do about it-my wife won't let me pull it in the living room- I ASKED; and I can't afford a storage space at the moment
Hopefully, this issue will be cured in the next couple months. I put the townhome up for sale, so we can get into a single family. My decision was influenced heavily by just the desire to have a house for my "baby". The wife and kid too, I guess......
#45
School me someone.
#47
They are not the same. Battery tender floats the charge and does not over charge as a trickle charger will eventually do. Trickle charger is always charging whereas a battery tender gets it up to about 14 volts or so then stops charging until at's at 12 something volts. Not sure about exect numbers, but you get the idea.
#48
i would leave my bike out in the snow before i would use a cover, especially outside. dust gets under the cover and then the wind blows the cover around on the paint, rubbing the dust around in the process
#49
Definitely go with the tender. And loose the blanket under the bike cover. Moisture can build up and cause condensation + rust. Put some Stabil in the gas tank, ride for awhile to make sure it's down in the system, and then you can store for a while. Make sure the gas tank is absolutely full to the brim. Any air in the tank can also cause condensation, and therefore rust and crap in your tank injection/carbs etc...
#50
I'll lose the cover(thought it would help start easier- it hasn't .
I'm not storing. I'm trying to ride straight on through. With a little help from my friend.....named Mr Gerbing
It's a 91, plenty of imperfections in the paint already. Not worried about the cover.
Smartbass
12-23-2013 09:28 AM
