Waterproof Glasses
You might try looking into Ski Goggles. I used to use a pair, even over my panoptics glasses. They covered more of my face and made the rain a little easier to take.
I don't think the swim goggles or the dive mask will work. Yer eyes will sweat without any ventilation. They may also fog up from the heat inside vs. the cooler air outside, just like when diving.
You might be able to hold back the inner fogging by using the same technique divers use... spit into the inside of the goggles and rub them around creating a layer over the entire inner surface, then lightly rinse them in a bowl of water. We use the ocean, but if you were to rinse them under running water like a faucet, it may wash too much of the 'protective' layer away. They also make a commercial anti-fogger for that. There is one there under the ad for the Aqua Sphere mask in the 'Customers who purchased this item also purchased:'...
Most people we dive with call it Monkey Spit or Camel Spit.
But, I still believe they could cause sweating around the eyes, which would be just as bad or worse than the rain water. Salt in sweat makes your eyes sting.
Ski goggles.
They're designed to conform to your face/head and will keep wind out of your eyes. But understand that anything will eventually let in some moisture. The seal on ski goggles is foam. Why? Because some air does need to pass in and out to prevent fogging. Good ski goggles are not cheap. Try a few brands to see what fits your face best; they're not all the same.
Dive masks and swim goggles will fog.
After many frustrating and frightening trips through rainstorms with my glasses becoming almost opaque as it rained harder, I discovered that removing the foam liner solved much of the problem. It doesn't seem to be the water on the glasses (a full face helmet's shield has plenty of water on it) but the moisture trapped inside the glasses that turns to fog. By allowing a good flow of air, I have been able to maintain pretty good vision.
By the way, I have one of the WileyX models with prescription lenses which provides a removable foam gasket.
I go with Bobsters
http://www.bobster.com/catalog/produ...Family=Cruiser
They are cheap and I've had them on in the rain and it did just fine. They are only like $20.
Since I now have to wear corrective lenses while driving.... I had to go with something like this....
http://www.globalvision.us/products/goggles/styles/windshieldcl.php
I have had occasional fogging issues, but lifted slightly and it went away. I use the scuba spit technique on the inside, and Plexus on my windshield and on the goggles... it works, but I still prefer my full face modular while riding in the rain.
They now have a anti fog coating...maybe I'll get some new ones?
