What to do at Red Lights that NEVER change?
Received 1,629 Likes
I don't think I should have to put anything on my DOT certified bike to make anything installed by the DOT work
Depending on the situation, I:
1. Run the light after waiting a cycle or 2. I do this if there is no traffic around, I also may time it to run it during a green of opposing traffic where no one is coming.
2. Get off the bike and go press the walk button (if there is one). I usually do this if there is alot of traffic going the other ways, but none lining up where they would trip my signal.
3. If I can see the wires, make sure the bike is straddling one (as mentioned).
Same here
Thats entrapment. If the light is known faulty, the city is obligated to fix it.
+1. This works for me 99% of the time. Rest of the time, wait one cycle, check traffic, yield right of way and cautiously run the light.
If you have a light that always fails to detect you, notify the DOT in your area.
Turn right, then make a U-turn at the first opportunity.
Used to be one I'd occasionally get stuck at after work. It wasn't on a timed cycle at all, some times cars wouldn't trigger it (the highway could have green light for hours). There was one cop who would sit and wait for people to get fed up and run the red light.
You don't need magnets. If you can see the wire in the ground, don't put your bike in the center of the box, put it directly over the wire on the right or left side, with your front wheel just past the end. This will trip the light almost every time. On the rare occasion it doesn't, run the light.
Here in Washington they passed a law about 2 years ago that says if a motorcycle doesn`t trip the light, you can sit through 2 cysles of the light and then proceed with caution, as if at a stop sign on a busy street. I tested this out at a light that wouldn`t trip. State cop pulled me over and asked why I didn`t wait for the light. I explained to him why and about the law. He agreed with me and let me go with just a "Ride Safe" parting....
My experience is that a good strong magnet does work but only at some lights, not all. Putting the kickstand down on the corner of the wire (sensor) sometimes works, but not always. Running the frigging light always works! I would never never get off my bike to press a walk button! That is insane and dangerous, IMHO. I have talked to local LEO's and told them about the signals that do not trip for bikes and have been told to just blow the damn light! If the traffic engineers are setting the sensors so that motorcycles cannot trip them, then screw 'em - blow the light.
Here is a link that lists the states where you're allowed to run red lights. Keep in mind the article is a year and half old.
http://www.usatoday.com/news/nation/...ght-laws_N.htm
South Carolina (2008), North Carolina (2007.), Wisconsin (2006), Idaho (2006) Arkansas (2005), Tennessee (2003) and Minnesota (2002).
Yes you can run a red light in Tennessee on a motorcycle, there is a little restriction in it, such as running a light that doesn't have a detector,, didn't know there were any left not that way now!!
T.C.A. 55-8-110
.(b) Notwithstanding any provision of law to the contrary, the driver of a motorcycle approaching an intersection that is controlled by a traffic-control signal utilizing a vehicle detection device that is inoperative due to the size of the motorcycle shall come to a full and complete stop at the intersection and, after exercising due care as provided by law, may proceed with due caution when it is safe to do so. It is not a defense to a violation of § 55-8-109 that the driver of a motorcycle proceeded under the belief that a traffic-control signal utilized a vehicle detection device or was inoperative due to the size of the motorcycle when such signal did not utilize a vehicle detection device or that any such device was not in fact inoperative due to the size of the motorcycle
T.C.A. 55-8-110
