Notices
Warming up on cold days
Old 11-17-2009, 10:15 AM
russell6hp's Avatar
russell6hp
russell6hp is offline
Default Warming up on cold days
Is it alright to leave my '08 Fat Bob on the kick stand while it warms up or should I stand it upright? Will the lean angle not allow it to lubricate properly? When it drops into the 40's I like to let it idle for a minute or two and it is more convenient to start it up and then start putting the gear on.
Old 11-17-2009, 10:37 AM
RonB's Avatar
RonB
RonB is offline
I think thats pretty much standard practice, By the time you get your gear on your ready to start out slowly. Ive been warming up Harleys on the side stand for 55 yrs no need to be concerned.
Old 11-17-2009, 11:21 AM
frog13's Avatar
frog13
frog13 is offline
It'll lubricate just fine, all day long, on the kickstand.
For safety reasons, you might want to consider laying it on it's side while it warms up, keeps the wheels off the ground in case you knock it into gear. Sorry, couldn't resist!
Old 11-17-2009, 11:37 AM
RoadKing_Bob's Avatar
RoadKing_Bob
RoadKing_Bob is offline
I was going to suggest 50 jumping jacks and 50 push-ups and a little jogging in place should do well.
Old 11-17-2009, 12:06 PM
cadman311's Avatar
cadman311
cadman311 is offline
Look at your oil pressure gauge. At a low speed cold motor has little to no oil pressure till you get the oil warmed up and some RPM"S. All day on the kickstand is push it a little bit to much bad info
Old 11-17-2009, 12:07 PM
oct1949's Avatar
oct1949
oct1949 is offline
Holly Chit................Wonder if those racers on oval tracks worry about lubrication while leaning in the turns..
Should let it warm up a minute or two all the time...!!!!!!!!!
Old 11-17-2009, 12:08 PM
Voony's Avatar
Voony
Voony is offline
Old 11-17-2009, 12:14 PM
carpetride's Avatar
carpetride
carpetride is offline
On really cold days, I find that sitting on the bike, starting it and immediately twisting the throttle wide open and holding it there for a couple minutes builds oil pressure and warms the bike up quickly so I can then shut it down to put on my fingerless gloves and assless chaps and not worry about oil starvation.
Old 11-17-2009, 12:21 PM
hornhonker's Avatar
hornhonker
hornhonker is offline
BMW car people suggest driving away pretty much right away but at low rpm and light throttle. The engines warm up faster which they feel is the key to long life.
Now for us I have read that this sort of thing with a Harley might create oil leaks of the cyl base gasket if the cyl heats alot faster than the crank case. I have no idea if this is true but I do let the engine idle while doing up my chin strap and putting gloves on etc.
Old 11-17-2009, 12:25 PM
frog13's Avatar
frog13
frog13 is offline
You know, I would argue that point, the heat will get it long before the lubrication fails, but alas, I do not want to argue anymore on this forum because too many take every post literally and are "experts" on HD because they read some book, saw a video, heard it from a friend's hooker's pimp or something. Oh crap, I almost forgot to check for grammar and spelling before I posted, also!
Quick Reply: Warming up on cold days
