SADDLEBAG BRACKETS
SADDLEBAG BRACKETS
DOES ANYONE KNOW IF USING EASY BRACKETS OR THE GHOST BRACKET MOUNTS WILL CHANGE THE POSITION OF THE SADDLEBAGS. I HAVE A FLSTC WITH SUPERTRAPP 2/1. THE BAGS ARE TOO LOW AND TOUCH THE MUFFLER.
Guest
Posts: n/a
RE: SADDLEBAG BRACKETS
It will depend on how your bags are mounted to the brackets. I just put on new bags and was able to adjust them to where I wanted them because my bags have never been mounted before. Might be a bit different with your bags.....
In general they mount to exactly the same place. You can call easy brakets tech support, I spoke with Tom there and he was very helpful.
I too have a FLSTC and bought the quick release kit from BubbaBrakes.com. They didn't move the bags at all. Just replaced the mounting hardware with a quick detach system.
I've seen other Heritages with the other types of systems and they do not appear to move the bags as well.
Good luck,
Rick
Good luck,
Rick
Guest
Posts: n/a
The easy brackets mount through the back side of the bag....I drilled my own holes....so I could have put them where I wanted them. IF you already have mounting holes on the top and you want to move them up you will just have to do something with the original holes.
ORIGINAL: Bluerose
I don't know how the bags for the Deluxe mount. Must be different than the standard Heritage Classic bags.
Rick
