Powder coating vs anodizing
Old 11-08-2009, 11:25 AM
rhinoWErX's Avatar
rhinoWErX
rhinoWErX is offline
Question Powder coating vs anodizing
Why would you pick over over the other?
I've got a set of rear sets from Storz that came in raw, machined aluminum, but i want them black. My first thought was that they should be anodized - not sure why I think that. But then someone said that anodizing fades and that powder coating would hold up better.
The billet triple trees I recently purchased look like they've been anodized, and I have some powder coated parts on the bike. I guess I always thought billet stuff looked better anodized (anodizing, if I understand correctly, soaks into the porous aluminum) because it doesn't seem to build up as much on the parts as powder coating does - highlight the beauty of the machine work.
Anybody in the know can shed some light on this topic for me?
Cheers,
-Jack
Old 11-08-2009, 02:07 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Colored anodizing will fade over time.I believe the build up is about .0001-.0002"per side with a minimal penetration.This all depends on how long it is plated.
Powder coating is a more durable coating which builds up much thicker than a chemical plating.
All depends on what look you want.
Old 11-08-2009, 02:23 PM
BLKBAGGER's Avatar
BLKBAGGER
BLKBAGGER is offline
Powder coat is much much more durable. Now days you can get it in just about any shade. They even have one that works like a candy. I goes on over another color for a color tint. Anodizing fades pretty bad over a short period of time. It also scratches easy.
Old 11-08-2009, 03:21 PM
leicafish's Avatar
leicafish
leicafish is offline
I also depends on the look you are after.
Hard Mil Spec anodizing with last a long time. (ie M16 magazine clips)
Power Coating lots of colors and textures now. But the longevity all depends on surface prep and pre coating. Bad prep and it will peel off like plastic.
Old 11-08-2009, 03:26 PM
faber's Avatar
faber
faber is offline
Even mil spec anodizing will wear.....quickly.
Old 11-08-2009, 04:53 PM
1flhtk4me's Avatar
1flhtk4me
Hard anodizing is used alot in the aviation industry.A lot of these parts(aluminum)will also get an epoxy coating or even powder coating on top of the anodizing.
The wear areas are normally fitted with bushings,bearings,thread inserts,etc.
Old 11-09-2009, 02:52 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
hey bud, we powder anidized colors all the time! why not just have us powder them in the anodized you want them done in?
Old 11-09-2009, 04:14 PM
nevil's Avatar
nevil
nevil is offline
Received 1,036 Likes on 774 Posts
Had no idea you could do that. I thought they were 2 separate processes. Learned something new today, I guess.
Old 11-09-2009, 04:21 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
they are two seperate processes but we have powder that is a spot on match for anidized colors... as well as chromes, golds, etc... sky is the limit with powder
Old 11-09-2009, 06:15 PM
SpyderTB's Avatar
SpyderTB
SpyderTB is offline
i have had many pieces powder coated for the farm and other cars i have built and without a doubt in my eyes go with powder
philc814
12-10-2012 05:21 AM
jcallesano
07-23-2010 08:36 AM
NYBill
04-02-2010 01:05 AM
ky_ace
03-30-2009 10:07 PM
Quick Reply: Powder coating vs anodizing
