**engine brake**
Old 11-07-2009, 07:35 PM
1skrewsloose's Avatar
1skrewsloose
1skrewsloose is offline
For pete's sake, we all use enginge braking, to suggest otherwise seems stupid, Faast ed, maybe, should take a refresher course on how to ride, if you don't use gears to moderate your speed, then you should ride an automatic honda or of such. If all you want to do is gas it and use brakes, then hike up your skirt and get a honda!!
  #52
Old 11-07-2009, 08:05 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
I've been around the block, buddy.
Have you ever twisted a crank? I have.
It wasn't fun, and I will do what I can to be easy on my current crank.
Perhaps you need to do some research, before you mouth off.
  #53
Old 11-08-2009, 04:33 AM
scoobysteve's Avatar
scoobysteve
scoobysteve is offline
Sorry if the bike cant cope with engine braking then the bikes engine/tran design is crap, no matter who makes it. Engine braking is a fundamental rule of engine powered driving/riding. Sod the engine and tranny I want my bike to stop in a hurry then I will use what ever means necessary and brakes combined with engine braking is a must FACT.
  #54
Old 11-08-2009, 05:06 AM
rkride's Avatar
rkride
rkride is offline
Engine braking is a must as you come down the side of the mountain. I fear that riding the brakes all the way down a mountain on a bagger would overheat the brakes and warp the disks anyways
  #55
Old 11-08-2009, 07:34 AM
curlydee's Avatar
curlydee
curlydee is offline
Before I would get my brakes that hot, I would use the run off lane.
  #56
Old 11-08-2009, 08:51 AM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
Duh,.... when the situation becomes a "must", I use the engine. Hello? Not so stupid here.
All I was tryin' to say is that I use it with caution and error on the side of being easy on the crank. I never said I don't do it at all, did I? Did I?????
Just tryin' to share here, I ain't debating so's I can run for office or sumfin'.
You guys are missing my whole point here.
The point was that your crank (03 and up) is a little more vulnerable than previous years and yankin' it around with HARD decels and downshifts increases the likelyhood of a large run-out situation. This translates to increased vibration, hotter running motors, eventually taking out your oil pump. Seen it happen, had it happen.
Take it for what it's worth. Just throwing you a "heads-up".
Do as you please, but insulting me ain't the answer. I really meant well.
  #57
Old 11-08-2009, 09:32 AM
1skrewsloose
Point taken, no harm, no foul.
  #58
Old 11-08-2009, 09:46 AM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
Peace.
  #59
Old 11-08-2009, 09:55 AM
schumacher's Avatar
schumacher
schumacher is offline
done it for years with no ill effects to any of my bikes
  #60
Old 11-08-2009, 09:58 AM
notfried's Avatar
notfried
notfried is offline
every vehicle i own is a standard and i downshift every one of them to slow down...just gotta listen and match rpm's
Quick Reply: **engine brake**
