Impact wrench advice...
Old 11-04-2009 | 12:47 PM
cactus789's Avatar
cactus789
Originally Posted by golfblues
Thanks all, I'll pick up this set for now. Harbor Freight 29.99
38 Piece 3/8", 1/2" Combination Impact Sockets
Entire set contains both metric and standard sized sockets for your 3/8" or 1/2" impact wrench.
  • Dropped forged, heat-treated, chrome vanadium steel
  • 1/2" SAE impact sockets: 7/16", 1/2", 9/16", 5/8", 11/16", 3/4", 13/16", 7/8", 15/16" and 1"
  • 1/2" metric impact sockets: 9mm, 10mm, 12mm, 13mm, 14mm, 15mm, 17mm, 21mm and 22mm
  • 3/8" SAE impact sockets: 5/16", 3/8", 7/16", 1/2", 9/16", 5/8", 11/16", and 3/4"
  • 3/8" metric impact sockets: 8mm, 10mm, 11mm, 12mm, 13mm, 14mm and 17mm
  • 3/8" x 1/2" adapter, 1/2" x 3" extension, 3/8" x 3" extension and blow mold case
Great buy!!
Up here we have Canadian Tire, I love that store,
$69 bucks Can. Lifetime Guarantee
  • ½" drive impact set
  • Made of chrome vanadium steel
  • Socket sizes are laser etched on
  • Anti-rounding corners
  • Includes 10 regular impact sockets (7/16", 1/2", 9/16", 5/8", 11/16", 3/4", 13 mm, 15 mm, 17 mm and 19 mm) and 18 deep impact sockets (3/8", 7/16", 1/2", 9/16", 5/8", 11/16", 3/4", 7/8", 8 mm, 10 mm, 11 mm, 12mm, 13mm, 14mm, 15 mm, 17mm, 18mm, 19mm and 22mm)
Old 11-04-2009 | 01:03 PM
piasspj's Avatar
piasspj
If your wanting to save money I'd get the 11 piece SAE and 11 piece metric deep wells they are $15.99 a set. (of course check for them on sale and get the 20% off coupon). It doesn't sound like you have a 3/8" impact. Deep wells are necessary for removing nuts when the stud or bolt protrudes.
Also for the torx bolts you might want to pick up one of these
http://www.harborfreight.com/cpi/cta...emnumber=37530
http://www.harborfreight.com/cpi/cta...emnumber=93481
Use your torx bits with it.
Old 11-04-2009 | 02:33 PM
Night Crawler's Avatar
Night Crawler
I never use impact wrenches driving TORX sockets but I do use an air ratchet at times. Using an air impact only leads to stripped bolt heads; and quickly too.
Get a “hand impact wrench” – the type you hit with a hammer - for stubborn TORX bolts.
Old 11-04-2009 | 02:56 PM
HDSAE60's Avatar
HDSAE60
Impact on a torx? not on my watch.
Old 11-04-2009 | 03:29 PM
Grammaton's Avatar
Grammaton
Impact wrench = impact sockets. You won't know there's a problem with the chrome socket until it's too late. I've seen some pretty painful injuries from chrome sockets on an impact.
Edit: If you want to save money, buy one socket at a time.
Old 11-04-2009 | 04:02 PM
FastHoss's Avatar
FastHoss
The only reason you use impact sockets is to prevent damge to the air hammer,not the other way around.
Old 11-04-2009 | 04:40 PM
farmerstu's Avatar
farmerstu
wrong wrong wrong
I sometimes use a chrome socket on an impact when tight space doesn't allow for an impact socket,HOWEVER chrome sockets can and do break under impact use and safety glasses and gloves are a good idea .
there are no stupid questions,no wrong opinions.but boy are there some bad answers.
Old 11-04-2009 | 04:49 PM
SpyderTB's Avatar
SpyderTB
My family has a farm that i grew up on and still work on. i have had many tools fail and yes they willl hurt you. DONT BUY CHEAP TOOLS. use the correct too for the job. If you dont they will fail and they will hurt you.
1/2" 11 piece 12 pt SAE set - http://buy1.snapon.com/catalog/item....re&dir=catalog
Old 11-04-2009 | 05:01 PM
oct1949's Avatar
oct1949
Impact sockets are named that for a reason....
I wouldn't use allen or torx in one. strip heads to easy. used to use driver impact with them.
Old 11-04-2009 | 05:32 PM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
I don't know where you got your information but you are 100% wrong.
Impact sockets are a different hardness, and have a heavier wall thickness than chrome sockets.
If you use a chrome socket on an impact wrench, it may or may not fail on initial use, but over time, it will fail...usually the drive of the impact will deform the driven end of the socket and it will split at the squared corners of the socket.
The chrome sockets are also prone to splitting due to the hammering and higher applied torque and can throw shrapnal out from the failed socket into eyes and hands.
The chrome will also flake off from the hammering and can cause like damage.
They actually put those warnings on the tools for a reason, and if you spend enough time useing them, you will see this 1st hand.
EdrikLT
General Topics/Tech Tips
06-20-2014 07:03 PM
Temporary Username 1
04-30-2014 01:01 PM
-Grumpy-
17
03-01-2014 04:00 PM
timberland
11-26-2009 03:54 PM
spiritwarrior
01-19-2009 11:11 AM
Quick Reply: Impact wrench advice...
