2 year warrantee question (what breaks?)
Old 11-03-2009, 05:25 PM
goo's Avatar
goo
goo is offline
Default 2 year warrantee question (what breaks?)
got a new xbones.
i was just wondering what kind of things people here have had break and then fixed under the 2 year warrantee.
thx,
goo
Old 11-03-2009, 05:52 PM
TMace's Avatar
TMace
TMace is offline
I had the rivits on the headlight bucket work loose, they replaced the entire headlight assy. Had a defect in the primary case, clutch cover mating surface had a groove in it that allowed the stock o-ring to seal but the gasket for aftermarket cover leaked. Dealer replaced entire outer primary case. The wiring harness for the rear brake light failed, no brake light, dealer replaced. That's about all the issues I had while under warranty!
Old 11-03-2009, 06:11 PM
schumacher's Avatar
schumacher
schumacher is offline
the engines blow up, the wheels fall off.....just minor stuff like that
Old 11-03-2009, 06:17 PM
golfblues's Avatar
golfblues
golfblues is offline
Received 1,540 Likes on 932 Posts
I have a 06 & 09(1 year so far). Never had a warranty issue with either. Lucky I guess. Nah, just good bikes.
Old 11-03-2009, 06:20 PM
Sefferdog's Avatar
Sefferdog
Sefferdog is offline
just got mine back from warranty repair about a month ago. Here is what was replaced. No cost to me...
Lifter noise
Part # Description Qty
11132a Filler plug o-ring 4
11145a o-ring 4
11270 o-ring 2
11293 o-ring 4
17386-99a Rocker cover gasket 2
18538-99b Lifters 4
18635-99b Tappet cover gasket 2
Clutch/primary noise
3368 Hex flange screw 1
37312-75 Clutch thrust bearing 1
39929-06a Primary chain tensioner 1
40037-07 Primary drive chain 1
40296-06A Compensator assembly 1
Transmission noise
11061a Retaining ring 1
11081a Locking ring 3
11082 Securing segment 6
11207 Internal spline washer 1
12052a Inner primary oil seal 2
12074 Oil seal 1
17369-06 Gasket Service Kit 2
27444-00y o-ring 2
34091-06 Inner bearing race 2
34901-07 Primary cover gasket 1
34917-06 Transmission top gasket 1
34934-06 Primary housing gasket 2
35078-79 Hex nut 2
35122-06 Driven output gear assembly 1
35654-06 Transmission bearing gasket 1
37101-84b Oil seal 1
37906-90 Clutch ball bearing 1
37909-90 Clutch circlip 1
5837a Spacer 1
786a Seal bolts 5
8026k Needle bearing 4
8963 Needle bearing 1
8967 Double row ball bearing 1
8970 Ball bearing 2
9231 Roller bearing 1
99851-05 Formula+ 2
Old 11-03-2009, 06:25 PM
'05Train's Avatar
'05Train
'05Train is offline
The bike caused whining from my wife. Warranty wouldn't cover it, so I had to get divorced.
Cost me half my $hit, but I still have the bike.
Old 11-03-2009, 06:40 PM
Wallaby's Avatar
Wallaby
Wallaby is offline
My engine cases leaked oil at the split at around 18 mths, got it fixed under warranty. They had to pull the motor and split the cases, flywheels out, everything. I wanted the dealer to put in SE stroker flywheels and big bore kit, but HD would not come at it. Tried every dealer within 200 miles, same story, no engine upgrades under warranty work! They finally agreed to swap out the cams and charge me just for the part, better than nothing.
Old 11-03-2009, 06:57 PM
Other Sheep's Avatar
Other Sheep
Other Sheep is offline
99 Heritage, none. 07 Heritage, none. Sons 07 WideGlide, battery.
Old 11-03-2009, 07:57 PM
futureratbike's Avatar
futureratbike
futureratbike is offline
My '09 FXD with 13,000+ miles...not a thing wrong with it, and not worried about anything going wrong with it during or after my one year of warranty is left.
Old 11-03-2009, 08:10 PM
08KING's Avatar
08KING
08KING is offline
08 Road King with 19400 miles and the Y pipe split, had 13 days left before the warranty expired.
Quick Reply: 2 year warrantee question (what breaks?)
