Brake Pads for Polished Rotors
I started polishing my rear rotor the other day and for those of you have polished aluminum from scratch know how time consuming and labor intensive it can be. Well, I decided to save time I'd just buy polished rotors and over the summer (I'm a teacher) I'll polish them up properly and sell them. While looking at rotors on Ebay I noticed some companies recommend organic pads on polished rotors. EMG makes them but then I read they leave a lot of dust, so those are out. Any recommendation without busting my wallet?
I'm confused. You're going to buy polished rotors and then polish them again over the summer in order to sell them?
If you have a super slick (polished) surface, it makes sense that the pads are going to have to be pretty soft in order to properly grip. Otherwise, they'll be useless until they've worn the polishing off the rotor.
Tires and brakes should be left alone, or only improved upon to increase performance. Not looks.
EBC Kevlars work for me. I've used them on both my stock rotors after I polished them and later when I put on el Cheapo polished rotors from eBay. I can tell no difference in the braking between polished and non-polished rotors.
Ok, let me unconfuse you - LOL. I'm buying custom polished rotors since I don't really have the time to polish my existing rotors. I'll be riding faster by buying them and waiting on shipping then polishing what is on the bike now. Over the summer I'll polish up the original HD rotors the right way and then sell them. Unconfused? Sorry I wasn't very clear, my mistake.
Okay, now I got ya. I probably just read it wrong.
When I polish I go through about 7 to 8 steps - from sanding with different grades to polishing with a buffer using several grades of polishing compounds. A rotor, done this way, will take several hours. I do all my polishing that way - just a thing I have about getting it perfect.
My problem is braking when wet . I believe the Chrome is whats causing the problem . I use Lyndall Z + and have in the past used E B C Kevlar
Who else has similar problems in the wet ?
