Another stupid oil question
Old 10-16-2009 | 09:09 PM
zeus33's Avatar
zeus33
Big Kahuna HDF Member
It doesn't matter what brand of oil was used originally you can add to it. Even synthetic and regular oil can be mixed, they are compatible.
Just drop by your harley dealer, pick up the proper oil for your bike and go ahead and top it off. They'll probably even do it for you. Actually, I'm pretty sure they'll do it, they're pretty accomodating most of the time.
If you need some help give me a shout and I'll pop over and help you out. We're neighbors afterall, I'm a Canadian.
Old 10-16-2009 | 09:10 PM
JW1200's Avatar
JW1200
Originally Posted by carpetride
You can add either regular oil or synthetic to bring the level up, but next change use just one type and remember it.
Don't do it!!
Old 10-16-2009 | 09:14 PM
carpetride's Avatar
carpetride
Originally Posted by JW1200
Don't do it!!
Geezus, I hope your not serious.
Old 10-16-2009 | 10:01 PM
KBFXDLI's Avatar
KBFXDLI
Lisa: You can top it off with any 20w50 motorcycle oil like HD360 or SYn3 or Mobil1Vtwin. Won't hurt a thing. Synthetics & mineral based oils are all compatible. No need to change for 5000 miles or 1 year.
Old 10-16-2009 | 10:18 PM
JW1200's Avatar
JW1200
We don't mix oil's So I would not recommend doing it. Oh hell, if your on a multi state trip and you need to add oil, you can get by with either. But it's a quick fix....
Old 10-16-2009 | 10:23 PM
JW1200's Avatar
JW1200
Just remember, OIL is the life of you engine. Old blues song by BbKing; Treat me mean! BTW I ride a 1991.
Old 10-16-2009 | 10:54 PM
HarleyGirl76's Avatar
HarleyGirl76
Originally Posted by seniorsuperglideE8
Just something interesting in your post. You said last summer, was that summer of 08 or 09? Does the manual say once a year?
Good question, yes it was 2009.(early July) I probabably don't have it done often enough because that was the first time I'd had it changed. I don't do a lot of miles except in the summer. I appreciate the feedback, I'll just have it changed again and ask them what they used.
Old 10-16-2009 | 10:56 PM
HarleyGirl76
Thanks neighbor. I'll try the dealership first.
Old 10-16-2009 | 11:14 PM
Jim Kraft's Avatar
Jim Kraft
I agree on mixing synthetic and dino. If you stop and think about it, we do this evey time we change from one to the other when changing oil. There is probably at least a half quart left in the engine after it has been drained. I have even thought of mixing half and half. The best of both worlds.
Old 10-16-2009 | 11:23 PM
SportsterBob's Avatar
SportsterBob
Maintenance is based on experience, needs and funds plus many others. The best way to learn is thru trial and error....There will always be 1,000 answers to one question when it comes to oil...Find what works for you and stick with it!
