Harley Cleaner and Polish
Old 10-12-2009, 05:23 PM
GarboHD's Avatar
GarboHD
GarboHD is offline
Default Harley Cleaner and Polish
Has anyone used the waterless Harley cleaner and polish? Good or bad results?
Old 10-12-2009, 05:37 PM
smithr's Avatar
smithr
smithr is offline
If you are talking about the stuff in the spray can, I use it on chrome only. When I use it on painted surfaces it seems to streak. Does a great job cleaning up chrome though. JR.
Old 10-12-2009, 05:43 PM
GarboHD's Avatar
GarboHD
GarboHD is offline
Yes that is what happened to me. Haved used a product called Opti-gloss with great results. Having trouble finding it.
Old 10-13-2009, 09:59 AM
hucks 08's Avatar
hucks 08
hucks 08 is offline
works great for me ,also lemon pledge .heard about it on here and tried it and it works real good
Old 10-13-2009, 12:41 PM
HarleyWood's Avatar
HarleyWood
HarleyWood is offline
it works OK as a cleaner, seems to cut the bugs pretty good on the windshield. Honda polish or pledge is a better polish IMO.
Old 10-13-2009, 01:23 PM
ultrapacman's Avatar
ultrapacman
ultrapacman is offline
Only use it on the windshield because of the streaking issue mentioned earlier. I like Meguiar's Quick Detail for the rest of the bike better.
Old 10-13-2009, 02:52 PM
skratch's Avatar
skratch
skratch is offline
Received 4,371 Likes on 2,543 Posts
i thought it sucked. not worth the money, imo. i usually go by the metric dealer and pick up a can or two of the 'original spray cleaner and polish' aka hondabrite (before they changed the forumula).
to get the bugs off, i use a 50/50 mix of peroxide and water in a spray bottle. takes them off super easy, then i put a coat of polish over it to help make it 'slicker' so bugs don't stick.
Old 10-13-2009, 03:05 PM
HarleyWood's Avatar
HarleyWood
I thought about giving an "it sucked" , but went with OK since it did cut bugs..
I haven't bought anymore since the first try.
I also use peroxide to cut the bugs and then follow up with Honda polish or Pledge
Old 10-13-2009, 03:38 PM
Gizmo83's Avatar
Gizmo83
Gizmo83 is offline
This is the best aerosol stuff I've found for removing grime:
http://www.blackfireusa.com/blivcaspcla.html
Old 10-13-2009, 04:04 PM
carpetride's Avatar
carpetride
carpetride is offline
how many people of polish decent does it take to shine a gas tank?
answer....3
1 to hold the rag and 2 to push the bike back and forth
Quick Reply: Harley Cleaner and Polish
