Starter
Starter
My wife's 2002 FatBoy appears to need a new starter. Can Harley starters be rebuilt or is it a throw away piece? How hard is it to change a Harley starter? What kind of starter would you replace the unit with? New, rebuilt, spyke,or some other method?
Thanks for your input!!
RE: Starter
ORIGINAL: harleyboy63401
How is it acting that you think you need a starter? Have you checked the battery and the cables on the other end where they bolt to the frame and starter? A lot of times it can be a problem with the ground cable at the frame.
RE: Starter
I have had the battery checked and all the connections seem to be good. It just seems to drag or hesitate upon hitting the start button. It is hard to believe it could be a bad starter with only 22,000 miles on the bike. Charging system seems to be good and battery is kept on a tender.
I talked to my local indie and he wants me to bring it by so he can diagnose it. He is generally pretty fair. Hopefully it doesn't need a starter replacement.
Thanks again for your input!
RE: Starter
Took bike in today to diagnose problem. Battery and connections good. I think he said the armature is going out of the starter. He said if it was his he would run it until it got worse. Not sure what I am going to do. I'll let you know later!
Thanks Again!
Thanks Again!
RE: Starter
Do you have a service manual for that bike? I had a similar problem with my old wide-glide. Turned out to be the starter clutch in my case, but the service manual should detail how to check the armature using an Ohm meter.
Oh yeah, remember, 2nd gear to push start.
RE: Starter
How many hours do you think should be charged for replacing the starter?
RE: Starter
I found the source of the problem. After Autozone, the local HD dealer, and Hot Bike dealer all said the battery was fine I decided to visit one last independant shop. He did a check with his meter and said that he thought it was the battery. He offered to put the new battery in for me to try and if that didn't fix the problem I wouldn't have to pay for it. It appears at this point that he was correct and the problem was a bad battery. No charge for diagnoses and installed the battery with only a charge for the battery itself.
I feel so much better now!
I guess it pays to get a 2nd,3rd and 4th opinion!
Thanks for all of your inputs!
harleyboy63401
harleyboy63401
