Chrome plating parts
Old 06-27-2006 | 10:57 PM
4merRacer's Avatar
4merRacer
Default Chrome plating parts
I recently purchased a chrome inner primary on ebay. The gasket surface was chromed also. How common is this? Can this be expected from Kuryakyn or Custom Chrome? Can chrome be removed from the gasket surface and still leave the rest in tact? Thanks for any info.
Old 06-27-2006 | 11:37 PM
71tradewind's Avatar
71tradewind
Default RE: Chrome plating parts
Chrome on the gasket surface shouldn't pose a problem.....my Harley Chrome plated stuff is on the gasket surfaces as well.
Old 06-28-2006 | 01:45 AM
wildman67's Avatar
wildman67
I don't think that should be a problem. (unless the bolt hole's ain't lining up!)
Old 06-28-2006 | 12:25 PM
fxstcguy98's Avatar
fxstcguy98
Leave it on there, if you remove it, it will start to corrode around the edges after a while. It will seal just fine, my outer has chrome on the gasket surface, no leaks.
Old 06-28-2006 | 12:41 PM
jt1965's Avatar
jt1965
Not a problem at all if the part is made right it should seal just fine(with a gasket of course). It is almost imppossible to chrome something and not chrome the gasket face, if there is no chrome on there it was machined off and that in itself can cause problems.
Old 06-28-2006 | 07:08 PM
4merRacer's Avatar
4merRacer
Thanks for the info and first hand responses. Those are the most trustworthy. Much appreciated.
flyingace
04-10-2014 05:05 PM
street53glide
03-17-2010 11:58 PM
BFREE
03-02-2010 05:17 PM
jm35ny
09-06-2009 10:17 AM
dshukwit
05-20-2008 10:29 AM
Quick Reply: Chrome plating parts
