Do Helmets Have a Shelf Life
Old 09-30-2009 | 09:15 AM
petemac's Avatar
petemac
I wouldn't wear it. Why find out the hard way when you can get a new helmet for reasonable money. Not the best place to be trying to save a few bucks.
Old 09-30-2009 | 10:11 AM
hullhorr's Avatar
hullhorr
Buy a new one
Old 09-30-2009 | 11:23 AM
UltraTheo's Avatar
UltraTheo
Yep, like others have said, time for a new one for sure.
Old 09-30-2009 | 11:45 AM
jimmything's Avatar
jimmything
Yea, 27 years, it would probably disintegrate in a cloud of dust if you landed on your head. Besides, the fashion police would nail you the first time you wore it again.
Old 09-30-2009 | 12:30 PM
oct1949's Avatar
oct1949
Originally Posted by davewear
they are given a shelf life because generally a helmet will have been dropped or the liner subject to contaminents within a 3-5 year period. there is no reason a helmet that has not been dropped and has been kept in an area away from paint/gas/etc fumes shouldn't be as good as it was new.
+1, (+) direct sunlight is also very hard on most anything, aging factor.
Old 09-30-2009 | 12:47 PM
HD 472's Avatar
HD 472
Originally Posted by whoop72
if u do research on this issue, the supposed consensus is that they do have a shelf life, generally said to be 5 years.
What he said.....
Old 10-02-2009 | 09:24 AM
peddler's Avatar
peddler
Thanks everyone for the input. And for those members compelled to read more into this thread than was intended.....
Wasn't trying to save a few bucks....
Wasn't suggesting a 27 year old helmet was or wasn't safe.....
Was just looking for input/opinions regarding one of those many questions that run thru mind on a daily basis.
And for petemac's reference to "reasonable money."
Isn't this the same forum with members that can go on and on about a $3 a quart difference in the price of motor oil that is changed how many times a year?
I love this place!!
Thanks again to everyone that responded with info.
Old 10-03-2009 | 03:59 PM
txfxstrider's Avatar
txfxstrider
Shoei guarantees some, if not all, of their helmets for five years from date of sale or seven years from date of manufacture, whichever comes first so I guess they think they should be good for at least five years. Personally, I think it is a cover your *** way to sell new helmets. Mind you, this is from someone who doesn't wear a helmet.
Old 10-03-2009 | 05:12 PM
MidnitEvil's Avatar
MidnitEvil
According to helmet manufacturers, helmets don't have a shelf life, and don't need to be replaced if they are dropped.
Helmets are designed to mimic your skull. Your skull protects your brain with a hard outer layer, and a layer of fluid between your brain and your skull. Fluid would be difficult in a helmet, so they use foam instead. If the shell is intact and undamaged, and the foam is intact and not compressed, the helmet is fine and will work as designed.
The only times you'd need to replace your helmet after dropping it would be if you happened to have a bowling ball in it when you dropped it (which would compress the foam), or, if you managed to drop it in such a way which caused a break in the outer shell.
schumacher's Avatar
schumacher
I had one spoil once.....was a mess to clean up
Quick Reply: Do Helmets Have a Shelf Life
