Oil Level
Old 09-19-2009 | 09:28 AM
bzxgdk's Avatar
bzxgdk
Default Oil Level
I have a LCD Oil Temp/Level Dipstick (PN: 63046-07A). I don't trust the read out, so I use it manually (by pulling it out and seeing where the oil level is on the stick. It is about half way between the add quart line and the full line. Should I add a 1/2 quart or just wait until next oil change. By-the-way, the display states the same.
Old 09-19-2009 | 09:30 AM
bcox's Avatar
bcox
Is it cold or hot?
Old 09-19-2009 | 10:00 AM
2whlr4life's Avatar
2whlr4life
Arrow what the manual says
If cold just use the mark as a reference; don't add oil unless really low.
Always check your oil hot, on the jiffy stand. Let it sit for a couple of minutes, then if it looks low add to the upper mark only.
Old 09-19-2009 | 02:34 PM
bzxgdk's Avatar
bzxgdk
It was warm at the time. Will take it for a ride and check when I get back home. BTW... I just check it cold and is about half-way between fill & full lines
Old 09-19-2009 | 03:09 PM
dennyo's Avatar
dennyo
Between the Lines is Perfect . when Hot.
Hair53
09-23-2013 05:36 PM
EdandGrace
08-05-2013 09:32 PM
l30bar
09-29-2012 06:10 AM
CVORoadKing2013
09-11-2012 12:47 PM
sparky_mo
08-27-2008 10:40 AM
Quick Reply: Oil Level
