04 ultraclassic rear tire
does anyone no how to replace the rear tire on a 04 ultraclassic i was going to buy one of the internet and change it my self using the dyna beads instead of balancing it any input would help thanks
If you are mechanically inclined, It is pretty straightforward. Lift the rear, Loosen up the rear exhaust hangers. It should not have to be removed. Loosen the axle and slide it out. Move the wheel forward and take the belt off. Lift the bike a little more and tilt the wheel to slide it out. There is kind of a cam on the axle for adjusting it instead of the old screw type adjuster. I do it off and back on in about an hour. Usually 3 beers.
